What type of power loss will a leaky throttle cause
Old Mar 15, 2019 | 04:02 PM
Dakota Evo's Avatar
I have a car on an FP Red car use to pull hard but feels lazy as hell now. I even had to change my VE from being in low 100 to low 90s. Is this causing a big power loss for my VE to change this much?
Old Mar 15, 2019 | 04:04 PM
Biggiesacks's Avatar
depends how bad the leak it, you should do a boost leak test.
Old Mar 15, 2019 | 04:08 PM
Dakota Evo's Avatar
thanks for the quick reply its pretty bad boost drops quickly on the boost leak test...and the boost controler is leaking and not from the little hole in the hallman mbc.....but i eliminated boost controler and throttle leak is big....car feels slow and even had to make big change to my VE
its a stroker car that went from like 105 ve to 91 ve due to boost leak
Old Mar 16, 2019 | 10:22 PM
Wicked_X's Avatar
The throttle body seals are a pretty easy install. I made a pressing tool with a screwdriver and some tape. The first time, I bent them and had to reorder new ones
if that's where you are leaking, then you have a massive boost leak! Those can leak bad. I couldn't hold more than like 3 psi without them letting it all out
Old Mar 20, 2019 | 12:36 PM
LetsGetThisDone's Avatar
You found a boost leak. You should fix it..
