Evo 8 FP 71HTA, Built 2.0 506HP 466TQ
Exactly the point. These cars don't really pickup with cramming timing into them. Most people aren't going to chase 4whp gains by adding timing at a certain level. You aren't going to find 50whp by adding 10 degree's if the timing is in the ballpark. Historically these cars are in the low teens for small turbo's and below 8000.
I don't understand how synchros are eaten up by torque. The only brake gears to same speed to allow slider to lock together. Too much torque means gears can shear off to me. Or bend the tranny shafts apart if gears hold. What am I missing?
You're taking my post way too seriously. I'm speaking of things like rebuilding the tranny in general depending on your driving habits. So in a rebuild or your shifting habits, clutch drag etc. I hope you'd be replacing synchros, gears, bearings and so on. Been there done that. Good luck
They're affected by either bad shifting or a failing clutch.
The Trans gears on the other hand are definitely affected by Torque, which is why you get them REM ISF treated.
That said, when VD is setup correctly, it does give pretty accurate numbers. The last time I had my car on a mustang, the VD graph I made the weekend before was within 5hp of the dyno.
tscompusa
Sep 23, 2021 10:41 AM
Midnightevo8
194
Aug 11, 2018 12:14 PM
Kevin Knight
28
May 20, 2011 05:36 AM
