805 whp evo ix 2.3l efr8474
Are you going to change the fuel pump system?
I see you're dropping pressure at the high rpm and high injector duty cycle range.
Emtron VE calc is awesome though! All those compensations.
Amazing results man, congrats! Do you think that in 3rd gear the power output would be the same or even higher? The reason that I am asking is because when I dynoed mine, at 3rd gear I was 50hp higher than 4th gear and my tuner dynoed the car on 4th gear
If you're dynoing 50hp higher in 3rd gear than 4th gear, I would assume dyno operator error or perhaps a strange boost control issue. Either way, if your tuner wasn't concerned with that outcome then I'd be concerned with your tuner.
i am running dual walbro 485 or 525 if i remember them and i stage them on boost.
Chris@AMS
54
Mar 11, 2009 03:22 PM
Chris@AMS
Automotosports - Illinois
26
Nov 8, 2008 12:42 AM
DTM
58
Jul 5, 2008 07:14 PM
