2.4LR w/6870
Old Nov 11, 2023 | 10:49 PM
CurseDSM's Avatar
Originally Posted by LetsGetThisDone
I mean. Our car makes the power. Usually the only way to get a PTE Gen2 6870 to the 1000 wheel mark on a 4g is 50-52psi and the big vband hot side. We don't have any instrumentation pre/post intercooler but I do wonder if we would pick up 20-30 wheel with a 4 or 4.5" core.
That would be cool to see the gains by just switching intercoolers. I know I have a 2.5" out on my turbo so I did 2.5 pipe to 3" inlet of the fmic then 3' to my tb. I felt like it would keep the flow of the air from the turbo at a steady pace then cool it off with the intercooler then back to the tb in 3" for maybe some extra power.
Old Nov 12, 2023 | 08:29 AM
matt1937's Avatar
Originally Posted by deylag
Its a 2.4L engine so it can't rev as high as a 2.0L.
My 2.4 LR rev limit is 8.6but i usually shift around 8.4. with the LR u get a little better RS ratio that allows you to rev a bit higher than the standard RS of the 2.4.
Old Nov 12, 2023 | 11:09 AM
CurseDSM's Avatar
Long rod or not its still alot of stress on then crank at that rpm. This is why I went down to a 2.2.
Old Nov 24, 2023 | 02:06 PM
5LEEPERISAH23I's Avatar
Is your CDI box mounted under your catch can?
Old Jan 30, 2024 | 04:28 PM
MRadjahoe's Avatar
Man that combo is beastly!!! What headgasket is that btw??
Old Feb 18, 2024 | 01:08 PM
Crazy evo kid's Avatar
You can get 1000whp with 2.0L engine?
Old Feb 19, 2024 | 01:29 AM
CurseDSM's Avatar
You must be pretty new to the scene, they make 1200 to 1600 whp on the 2 liter engine and not that fake *** Extreme tuners crap either.
Old Feb 20, 2024 | 01:46 PM
bro..
i talked about the 6870 on mustang dyno
Are 2.0 4G63 can make 1000whp
With 6870 turbo
that was my question..
Old Feb 20, 2024 | 03:53 PM
CurseDSM's Avatar
bro..
With 6870 turbo
Ah ok thanks for clearing that up and the answer to that is yes they can with supporting nods.
Old Mar 1, 2024 | 01:51 PM
JohnBradley's Avatar
bro..
With 6870 turbo
Yes it takes about 54psi on a Dynojet to make a 1000. It is easier with a 2.2L but then you end up with an engine that you need to keep the revs down 800rpm less. That being said we still take them to 9800 and I am pretty sure the 1007 at 50psi on the 2.2 was still at 8100.
Old Apr 27, 2024 | 06:29 PM
DSMking90's Avatar
Damn this is amazing. So happy to see you say you are using the Siruda Headgasket cause i did SOOOOO much research before buying it and only found one guy in the UK that had run it. I bought it and you are having success with it so i should be good. lol
I am currently getting my setup going which is very similar except i have a magnus v5 manifold, built ported head and the turbo is the new Xona rotor XRE6869S so I am stoked to see what happens. Def need to get better ignition system and other little things.
Old Jul 10, 2024 | 07:41 PM
wantingtobuyevo's Avatar
Dude this is insane, if I may ask around how much did this cost?
Old Jul 10, 2024 | 11:37 PM
MuslimEvoFreak's Avatar
Yeah, turbo wouldnt make more boost. Sorry, it was 945whp. This was 45psi. Car traps about 150 in the 1/4 at full weight, and running street tires. AFR is also street fun safe at an 11.0.
(This the part where I make a comment about mustang dyno numbers being "variable", seems like yours reads about on par with a dynojet)
Where are you measuring coolant pressure? If in the block or on the head, 8psi is way low. The water pump will make 40psi+ in the block with thermostat restricting flow. Take the thermostat out and that pressure drops significantly.
If in the upper hose or inlet tank on the radiator, 8psi is pretty normal if your coolant temp is normal.
It's being measured from the head via a sensor and Link. I'm judt happy I'm not popping a gasket. Lol
Old Jul 10, 2024 | 11:39 PM
I 3D printed a custom mount that mounts to my master cylinder and it holds the box perfectly.
Old Jul 10, 2024 | 11:40 PM
I'm using a Siruda 87 mm head gasket and I am o-ringed. Thanks man!
