Speaker Sizes?
Old Jun 21, 2006 | 08:52 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Originally Posted by LilJapnBoy
M3this,
I redid the audio as one of my first mods. Replaced all stock speakers, head unit, and added an amp.
I ended up running MB Quart RSD-216 (components) in the front and MB Quart RWE-160 in the rear.
Some install notes:
- I ordered 6.5" and they were too small and need 'custom' mounting brackets
- The tweeters were 1" and were perfect fitment
- Redid all the speaker wire and it was a PITA to string the wire through the boot between the door and the frame
- The stock tweeters were torqued very tight to the brackets
- Changing the head units was the easiest part of the install
- Mounted Amp to the wall of the trunk instead of the floor to save space
- Opted against a separate sub band pass box/bazooka tube due to weight and space
Good luck!
Thats pretty much the same thing I'm looking to do. Thansk for the tips ..... how did you fix the speakers being too small?
Old Jun 21, 2006 | 12:14 PM
M3this's Avatar
Hey guys I made a suggestion to the admin about opening a ICE / Audio forum for the evo ... so if you think its a good idea support it by posting here:
https://www.evolutionm.net/forums/sh...d.php?t=207365
Old Jun 21, 2006 | 12:29 PM
kmcconn9's Avatar
The speakers are 6.5 but you will need a 6 3/4 adapter....
Tweeter as everyone has said is 1" and the depth clearance depends on how you mount it..
Factory sub is 8" with no more than 4.25" mounting depth..
Old Jun 21, 2006 | 12:30 PM
kmcconn9's Avatar
MB Quarts are nice, but not as nice as 2 sets of kicker SS's....booahaha
http://www.cardomain.com/item/KIC04SS652
Old Jun 21, 2006 | 01:02 PM
f-dub's Avatar
Originally Posted by M3this
Since there are no EVO audio forums I thought I would post this up in here. Can some please tell me what size speakers will fit in the stock locations on the evo?
Audio questions go in "Evo Show & Shine" usually.
Please fill in the following:
Standard Stereo Set Up:
Front Doors = 6.5"
Front Tweeter = ~1.0"
Rear Deck = 6.5"
Sun / Sound / Leather Stereo Set Up:
Front Doors = 6.5"
Rear Deck = 6.5"
Sub= 8"
Thanks for any help anyone can provide.
For SSL the front and rear speakers are the same size (6.5" woofer with a 6.75" bracket around it). Most aftermarket speakers will come with an adapter bracket that will fit these locations fine. Alpine brackets work great in the front, but are a little too small for the rear so some sort of gasket needs to be placed around the speaker so it doesn't vibrate against the rear deck.
The stock tweeters are about an inch in diamter. There is plenty of room in all directions for most any aftermarket tweeter, especially if you don't use the stock mounting bracket and mount them directly to the A-pillar instead. Even if you use the stock bracket, it is quite easy to get an aftermarket tweeter to fit on it.
The stock subwoofer I believe is 8". I don't see any point in replacing this speaker since it won't work with any aftermarket amp. You are better suited by getting an aftermarket box and placing that in the trunk than trying to get this speaker to work.
Old Jun 21, 2006 | 01:04 PM
LilJapnBoy's Avatar
Unfortunately I didn't have mounting brackets so my 'custom' method was to tear out the old speakers and use the original frame as the brackets for the new speakers. They worked well since it was just a matter or attaching the new speakers to the old frames which then bolted in tho the original mount points into the door, etc.
Guess this is not an option if you plan to keep the OEM speakers. I'm sure any stereo shop could throw together some mounting brackets or spacers betweeen the speakers in the door.
On a final note, the MB Quarts included mounting brackets however they weren't a fit into the doors or back.
Old Jun 21, 2006 | 01:16 PM
f-dub's Avatar
A router and some 1/4" MDF is another way of making brackets. Most stereo shops that do installs carry the required brackets though.
Old Jun 21, 2006 | 07:37 PM
Good_Enough's Avatar
If you order speakers through Crutchfield, they supply the speaker adapter brackets for free.
Note: this is for the door or rear deck area, not the tweeter.
Per what LilJapnBoy said, is correct, trying to pull the wire though the door boot is a real pain! I ended up cutting two slits on each side and basically bypassed the boot.
Maybe tomorrow I can post some more pictures of the install, including the speaker bracket.
Old Jun 22, 2006 | 11:13 AM
M3this's Avatar
Hey guys I complained enought and it has now been done:
https://www.evolutionm.net/forums/fo...play.php?f=180
We not have a Evo Audio / Sec forum!!!!!!
Hey mods please move this thread there! Thanks!
Old Jun 22, 2006 | 12:57 PM
lil'evil_evo's Avatar
that's crazy you got your own forum lol, 6.5 will work with a little work.
Old Jun 26, 2006 | 10:34 AM
EvilBlueEvo8's Avatar
pioneer makes 6 3/4" speakers that will fit. the depth on the front door is 2 3/4" inches and the front tweeter depth is 1". the back is pretty much any depth depending on magnet size. there are also lancer specific 6 3/4 to 6 1/2" speaker adapters that you can order. i have the link at home. they are about 12 a pair.
Old Jul 3, 2006 | 02:22 PM
dan628's Avatar
Has anyone taken out the factory sub and put in maybe a 10 or 12, using the stock amp? How did it sound. I like the way the stock setup sounds, but missin the BOOM of 2 12's, I was thinking of just adding a different sub and keeping everything else, any thoughts?
Old Jul 4, 2006 | 09:34 PM
twEeker's Avatar
I just put infinity kappa 6 3/4 in my mr. The speakers will fit fine, but since crutchfeild doesnt think they will fit, I had to make my own custom brackets, which was somewhat a pita, other then that they fit fine. Just thought I'd share my experience since everyone says 6.5's are the only ones that fit.
Old Jul 4, 2006 | 11:08 PM
twEeker's Avatar
So you still have the link?
Old Jul 5, 2006 | 12:01 AM
EvoTio's Avatar
Great information to know when I'm ready to do my stereo install.
