US and UK wiring
2005 Lancer Evolution
12 volts white (40A) + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Second Accessory blue/white (not required) + ignition harness
Keysense blue ignition harness
Power Lock purple to yellow - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ green/yel (L), green/wht (R) + white plug bottom of fuse box
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - white plug bottom of fuse box
Dome Supervision use door trigger wire
Trunk/Hatch Pin green/orange - light in trunk
Factory Alarm Arm arms with lock
Factory Alarm Disarm gray - driver kick, door harness
Disarm No Unlock see factory alarm disarm
Tachometer black/yellow or black/green ac either ignition coil
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - horn switch
Should be same for both, but use a meter and check carefully.
the reason i asked what kind of car he was looking for is because there are differences between versions of cars sometimes. plus he lists that he drives a camaro and not an evo so i wasn't taking an evo for granted. those colors you list are correct for a 02 - 05 us spec lancer, lancer es, lancer ralliart, and lancer evo viii. i have not worked on an 06 lancer (any version) yet so i can't confirm that they would be right, but there is not reason to doubt they changed.
now if we are talking evo's, the uk did have different lock colors/lock system.
uk evo7
Power Lock - yellow/red - 5wi - offside kickwell fuse box
Power Unlock - white - 5wi - offside kickwell fuse box
uk evo8
Power Lock- blue/red - 5wi - drivers kick
Power Unlock - white/siler dots - 5wi - as above
oh and there actually is a mistake with your colors. lancer do NOT have isolated parking light circuits. i've actually seen a bunch of wiring sheets listing it the way you did. i have no clue where that came from. the green/white actually powers both sides.
Parking Lights + green/white - wht plug bottom of fuse box
uk evo7
uk evo8
ez76
131
Jul 1, 2004 03:51 AM
