Need Help With ECU Fuse....Blowing
Old Aug 22, 2006 | 07:13 PM
OtownEvo's Avatar
I need some advice on which way to go....I was in middle of data logging last night with my zeixtronix and Utec when on the third pull on the street the car went DEAD.
Was in middle of third pull when motor turned off was at low rpms...To make long story short Pulled utec out..Still No fire from car...Just turn over and over...
Got some advice from A friend said (TTP-Engineering) could be ECU Fuse so in today checked that. As friend (SCOTT) Said the fuse was bad so I changed it. Car fires right up. So I think I am good....So put car back together and head to work half way there car died again?????
So it blew a fuse again...And now as soon as I replace it and turn ignition on it blows before I can start the car.......
Any Advice on what I mat be missing or anyone else had this problem PLZ HELP>>>>
Old Aug 22, 2006 | 07:19 PM
Nad1370's Avatar
Buddy of mine had the same problem and found out it was his turbo timer/harness that was shorting out the 15amp ECU fuse.
Old Aug 22, 2006 | 07:33 PM
fishing_ndw's Avatar
Do you have the anti-foulers in your exhaust to avoid the misfire code (P0300?)? The anti-foulers caused my oxygen sensor to rub against the underbody of my EVO and ground out. Grounding out caused the engine fuse to blow.
Hope this helps...
Old Aug 22, 2006 | 08:49 PM
TTP Engineering's Avatar
To: OTownEvo
Sent: Tuesday, August 22, 2006 10:01 PM
Subject: Re: Re:
Your rear O2 may be grounding on the chassis. Check your rear O2 on the exhaust. Many times when you install an CEL fix it pushes it out where it hits the underside of the car and touches the wire, blowing the fuse.
Check it rear O2 under the car for damage.
Poltergeist
Lancer Troubleshooting
Aug 15, 2015 07:53 PM
PorkRoll
Feb 28, 2007 09:36 AM
vtlaxplaya16
Jul 5, 2006 05:02 AM
AndyBandy
13
Nov 24, 2005 06:22 PM
nebolic
Dec 23, 2003 08:42 PM
