Trouble Installing trim on new HU
Here's the way to get the best IMHO... Transfer the stock mounting brackets to the new HU, then shim behind the ears of the mounting brakets with washers. The trim ring will then fit flawlessly. I did this with my Alpine, and it looks like a pro put it in. Just perfect.
Thanks for all your help guys. I went with the washers behind the ears method. I had to put three washers behind every ear so the trim could fit.
to all you guys. Thanks
trim...yes
i spaced the head unit out with washers and mine fit perfectly...you can see pictures at www.cardomain.com/ride/2439460 ...i can't get my pictures to work on here
GREAT timing for this thread!
I just installed a Kenwood in my new car last night and had the same problem. The Kenwood trim ring finish matches the stock dash trim color in my car perfectly. But the trim ring does not fit. I'm going to run out to get some washers to try that method tonight.
hey guys I know this is kinda old but I jus bought a Alpine head unit (CDA-9856) from a buddy. He didn't have the trim that goes around the the unit. got any ideas where I would be able to find a trim that would work?
Originally Posted by M00kiE
install the trim piece on the radio first. Then install the dash piece over that.
did that make any sense? LoL
Well, I'm glad to have found post on this subject. I would just like to announce that using spacers, washer or what have you work great. I was able to install my kenwood with the trim without a problem. I tried it w/o the trim to begin with but, the trim would not install.
However as long as you use some spacer this will work great
. I think that a good idea would be to tack the washer to the original brackets
, this might just make it easier to install. I had trouble with the spacers not staying in place when installing.
In the end the unit looks great like this. However, I am not sure if it is just me, do other lancer evo owners notice that the unit is slightly tilted toward the passenger? Mine has a flip out screen and it is not as easy to read from the driver side (the viewing angle is not as good).
Laters,
Brian
Laters,
Brian
gomezgoku
Mar 3, 2011 12:41 PM
mobman
12
Mar 7, 2010 12:23 PM
gomezgoku
12
Sep 6, 2006 11:23 PM
