adding sub to stock deck?
Old Aug 29, 2006 | 05:55 PM
ApexVIII's Avatar
how do you add a sub to the stock deck? i think the stock speakers sound really good just a little more base so i would like to add a sub. but i dont want a deck, so it looks stock. any ideas?
Old Aug 29, 2006 | 06:54 PM
scoob2evo's Avatar
does the stock headunit have rcas?
Old Aug 29, 2006 | 06:55 PM
scoob2evo's Avatar
hahahaha or just turn the bass up on your stock unit hhaha
Old Aug 29, 2006 | 07:00 PM
dbdude's Avatar
If you want it done right, then get a rca converter. Then add an amp and sub to that. Or most small amps have high level inputs too. Amps that have this dont require RCA plugs. Just splice into any stock speaker wire and your set. I must warn you- your gonna get lots of alternator whine thru your sub if you dont go with an aftermarket deck.
Old Aug 29, 2006 | 07:09 PM
eag36's Avatar
The easiest possible thing you could do would be to buy the infinity basslink or one of those bass tubes and hook it into your speakers. No need for RCA's or converters. It wouldn't be amazing rattle your car bass, but it will be compact enough to fit under one of the front seats (I think the infinity basslink would, i know a bass tube would not). It would also be a lot lighter than a separate amp, sub, and box.
ApexVIII's Avatar
oh ok. well ill juet get a deck then. i remember on my dads F250 he had a stock deck and a 800 amp and 2 10s and i dont remember there being any wine.
is there a relocation kit to move the stero down and add a pocket or something where the old stereos are? kinda like the gauge and stereo swap for IX's?
Old Aug 30, 2006 | 01:44 AM
DontRevMe's Avatar
Its basicaly impossible to get alt whine through a 50hz subwoofer...
No you do not need to change your stereo
AVOID infinity basslinks...trust me..
you need this
http://www.circuitcity.com/ccd/productDetail.do?oid=89601&JSESSIONID=G1PDXMLrYyNZ JMZsHTg1bT1J6FvfpL!-2099231457!1156927427646
Old Aug 30, 2006 | 07:13 PM
SpinOne05's Avatar
I have heard the JL Audio cleansweep in a friends car and it produced good clean sound. You might want to look into that also.
Old Aug 30, 2006 | 11:09 PM
DontRevMe's Avatar
thats more for a full system with a stock stereo.
Old Aug 31, 2006 | 08:47 PM
Kaneto's Avatar
I've heard quite a few people say that those line output converters can burn out if you put too much power through them. They tend to have a pretty low wattage capacity.
I'm using an amp with built-in highlevel inputs with the stock radio in my jeep and it sounds pretty good. Unless you already happen to have an amp you want to use, I'd look for some with high level inputs.
Old Aug 31, 2006 | 10:49 PM
DontRevMe's Avatar
peripheral makes line out's with different power ratings.
Old Sep 5, 2006 | 08:41 AM
fevo's Avatar
just buy an amp that accepts speaker level input
This Guy
Jan 18, 2013 07:05 AM
fast&crooked
Feb 21, 2011 12:26 AM
adammartini
Feb 12, 2010 06:40 AM
dbsears
Apr 2, 2008 05:57 PM
smp3000
19
Mar 12, 2007 08:49 PM
