Who's running a component set?
Old Oct 15, 2007 | 03:32 PM
  #91
NYC EVO's Avatar
Kicker RS component's powered by a kicker ZX650.4.
Old Oct 18, 2007 | 12:57 PM
  #92
buddha1320's Avatar
two sets of mtx t6001 powered by mtx te4004
Old Oct 18, 2007 | 01:08 PM
  #93
yahu's Avatar
+1 for Focal's. 165k2p via JL 300/4. Outstanding sound from the Focal's - very loud and not overly-ear-piercingly bright, but not muffled in the least.
Old Oct 18, 2007 | 01:48 PM
  #94
Mr. Evo IX's Avatar
a/d/s/ 346is components powered by PPI PC4800. I havent had these in a car in a while if anyone's interested pm me. The a/d/s/ tweeters are top notch, loud and clear but no ear fatique even at absurd volume levels.
Old Nov 11, 2007 | 07:07 AM
  #95
NocturnalEVO's Avatar
I figure i'll ask in here since so many people have components/amp. setup.
I have a JL Audio 10w6 sub and JL Audio 500/1 amp for bass.
I'm looking to upgrade the interior speakers to components. I'm not sure at all what to go with.
I'm lookin for some nice hitting mid-range bass, and clear highs. I listen to a lot of house/trance music.
Which one of the above mentioned setups would be good for that? what do you guys say lol
Old Nov 11, 2007 | 09:28 AM
  #96
YtDiamond05's Avatar
Polk momos have a ton of midbass for house/trance.
Old Nov 11, 2007 | 09:45 AM
  #97
TempeRacerGuy's Avatar
are you going to run an amp for the surrounds? I am a fan of Polk db6500.
Old Nov 11, 2007 | 11:03 AM
  #98
Yea i definatley want to run an amp!
What amp do you guys reccommend?
and what speakers should I run in the rear shelf?
Old Nov 11, 2007 | 08:47 PM
  #99
Honestly I would invest in a nice set of fronts and 2 channel amp, and do no rear speakers. I have only fronts with an amp in my car and its sounds great! Its all in what sounds good to you. Dont forget the dynamat!
Old Nov 12, 2007 | 05:53 AM
  #100
I run an alpine 4 channel amp for my surrounds that's 4X100. For normal listening, my rears add just enough filler to make my sound stage seem infinately wide, when I am running DVD Audio's I have it set for equal volume from all 5 channels.
Old Nov 12, 2007 | 10:29 PM
  #101
hennessey01's Avatar
Infinity comps with alpine 75wX4
Old Nov 15, 2007 | 10:00 PM
  #102
mike407's Avatar
mb quart w alpine mrd-540
Old Nov 16, 2007 | 01:55 PM
  #103
do you guys recommend dynamatting the entire door? or just around the speaker?
Old Nov 16, 2007 | 02:37 PM
  #104
atombomb33's Avatar
EvoM Community Team
I would recommend covering the inside of the door (the inner part of the outer sheetmetal) with as much dynamat as you can (it's hard to reach your hand inside and get the whole panel). Or the spray sound dampener could work well on the inner part. Than, cover the entire door with dynamat making sure to cover all the holes (except the speaker hole of course). This will do two things. Dampen any resonance from the door panel so that it is a solid mounting surface for the speaker. And it will also effectively create somewhat of an "enclosure" for your speaker since it will seal off the front sound wave from the rear sound wave. Highly recommend covering the entire door for the best sound possible.
Old Nov 16, 2007 | 03:05 PM
  #105
thanks!
