Pioneer AVIC-Z1 + Orbital Double Din
Was in middle of installing the z1 to my evo 9 and got kind of stuck
I have the upgraded oem speakers(Infinity)
there was a wire where the end was a shape of a dime and it came out from my stock cd player.
when i put the new navi in, with the harness, i hooked up everything including the vss, ebrake, bluetooth, rear light, speakers, etc. but i could not find a hole where i could fit the dime shape plug from my oem subs.
when i tried without that plugged in, the navi works great but with absolutly no sound.
am i supposed to buy a piece that fits that plug to the back somehow? can anyone help?
thanks
thanks
thanks
thanks
That wire is what ALL of your SPEAKERS run through from the amp(Not just the sub). That's why you get no sound. You need to get an adapter that plugs into that wire/plug which then splits into RCA jacks for the back of your new unit. Good Luck.
I believe this is what you need:
http://www.discountcarstereo.com/detail.aspx?ID=434
omggg that loooks sooo right!!
im going to go to a few stores tommorow morning and buy that, thank you soooo muchhhhh i was sooooooooooooooooooooo frustrateddddd
just bought a drill and some more butt splices. hopefully will have it done over this weekend. and actually, the kit fits nice and i loveee the metallic color! almost 100% match with the metallic around the shift knob
ill take the pics of my finished navi tonight!, i just finished. one small problem though.. it seems that i have lots of gain. as if the output is so strong that my speakers cant take it?
when the navi is on, i hear a psssssssssssssssssss in the back ground. when i put the volume to like 5, its already LOUD! and it goes to like 40.
did i make a mistake on the wiring?
some kind of system setting that i cant figure out???
i basically bought the harness that connected the infinity speakers to the navi. i spliced the black and red wire to plus and minus in front left front right back left and back right.
Problem Solved! just purchased another harness again. and didnt splice anything and just plugged the rca connectorinthe back of my navi.
k pictures will go up VERY SOON! and ill write a detailed review on what i think about this combination.
Z1 + Orbital
Z1 + Orbital
Richard L
61
Jan 21, 2016 05:20 PM
ikt
For Sale - Wheels / Tires
May 14, 2013 01:47 PM
billabong687
08+ Lancer Show / Shine
Jan 24, 2011 09:41 AM
The one for the Lancer will work for you. It worked for my Pioneer Headunit.
