AVIC-N3 Installation/EVO9
Old Mar 19, 2007 | 05:02 PM
johncloo's Avatar
Question AVIC-N3 Installation/EVO9
Hello all! I will be installing a Pioneer AVIC-N3 into my EVO9 and I was looking for info as to where I should tap into the Speed sense. I did a seach for ECU wiring diagrams, and I found one that had a picture but the link was broken. Any help on this install would be much appreciated!
Old Mar 23, 2007 | 06:29 AM
NoTec's Avatar
Its located in the OBD2 port, underneath the drivers side of the dash, above the gas pedal area. The wire is a white/black wire, or black/red, depending on what year vehicle you have.
Old Mar 26, 2007 | 09:23 AM
Hen5000's Avatar
I did a bit of research and i'm starting to get really confused on the adapters we need to buy for stock speakers. So to confirm I need 2 adapters to get the N3 to work with the stock speakers and sub? I currently own an 05 Evo with SSL
Correct me if i'm wrong I did some searches and it seems like i need
MITSRCVR adapter for the speakers
And this harness for the amp?
Old Mar 26, 2007 | 06:24 PM
rlui0514's Avatar
Hen5000* i believe metra makes one harness for both of ur needs which is the METRA 70-7003 if you go on the metra site you will find it hope this helps
Cyrax91
Jun 4, 2015 06:47 AM
coolguyuno1
Mar 12, 2008 03:02 PM
antonio010
Dec 17, 2006 06:43 PM
Tweak3D
Mar 20, 2006 11:11 PM
J8dailo
Aug 25, 2005 03:51 PM
