Do amps die?
Old Aug 15, 2007 | 09:54 AM
sgand's Avatar
Do amps die?
A few weeks ago I noticed that my sub wasn't on. I went and looked at my amp, and the power light wasn't on. I checked the connections to the amp, and the power wire was pulled out because the box slid across the trunk. Recrimped it, plugged it back in, rechecked all connections on amp, sub, battery and fuses....and everything is solid. Still isn't working. WTF?? Is it possible for an amp to die? It's probably 5 or 6 years old.
Old Aug 15, 2007 | 09:58 AM
diviniti's Avatar
Very possible for an amp to "die". You could have shorted it out or it could have not liked the slamming around. This is why you always secure it so it will not move around.
Old Aug 15, 2007 | 10:00 AM
sgand's Avatar
Yeah I never had that problem with it sliding around. Just one day I opened my trunk and the box was at the other side where I put it and the carpet was all folded to hell.
Old Aug 15, 2007 | 10:07 AM
diviniti's Avatar
You could pop it open and trace the current, to verify if you shorted it.
If its old though, and or a low quality amp, just drop a couple bones on a new one.
Old Aug 15, 2007 | 10:18 AM
sgand's Avatar
Ok, just did some poking around. I took a voltage tester to the input screws (where you screw down the power and ground wires), and it beeped at me. Tested the battery to double check the voltage tester, and it beeped at me. So I either need to open up the amp and test some internal wiring, or just put in a new amp and see if it works. There is no reason the remote wire would have any part in this right?
Old Aug 15, 2007 | 10:26 AM
sikrsix's Avatar
You can use a jumper wire from your power input to the remote input and if your amp turns on its your remote connection.. quick and easy to do..
Old Aug 15, 2007 | 10:30 AM
sgand's Avatar
What do you mean, can I just bridge a plain speaker wire from the bat. to the rem. input and find out?
Old Aug 15, 2007 | 10:33 AM
lexat20's Avatar
A fluke beeping usually means there is continuity. You need to check and see what the voltage reads
Old Aug 15, 2007 | 10:37 AM
sgand's Avatar
It doesn't read anything. It just lights up and beeps. Cheap $5 Wal-Mart tool.
Old Aug 15, 2007 | 10:42 AM
sgand's Avatar
SUCCESS!!!!!
Did the speaker wire bridge, and the amp's light turned on. Now me and the mad scientist have to rip apart dash and check the remote connection.
Old Aug 15, 2007 | 10:46 AM
sikrsix's Avatar
yes about 3" of wire is all thats needed, and only the thickness of a remote wire (so speaker wire would work) touch the power wire (while its hooked up) with one end and your remote with the other.. should power up within 3 seconds.
Old Aug 15, 2007 | 10:48 AM
sikrsix's Avatar
SUCCESS!!!!!
Gotta love those cheap and easy tests huh? Good luck, glad I was of some help..
Old Aug 15, 2007 | 10:52 AM
sgand's Avatar
Yes, thank you for that. I'm glad I didn't have to take the amp apart.
Old Aug 15, 2007 | 11:17 AM
sgand's Avatar
Took the radio out, and the remote wire was disconnected. I thought I saw it connected when I took the unit out the first time. Ah well, everything is working now.
pignosesr
Northwest Region
Jul 29, 2011 07:54 PM
c900t16
Nov 21, 2007 10:08 AM
sykou
18
May 14, 2007 09:44 AM
pumpdog720
Sep 7, 2005 07:05 PM
platinum drew
28
Dec 15, 2003 11:44 AM
