LC-1 erradict readings
i took it out cuz its pretty worthless... but i do have the harness still. Guess i can tap into that.
would you say your succes came from re-doing the grounds? or from re-doing the power?
...probably both...
...probably both...
both and do another open air after (this things such a pain in the ***
i dont mind the open air part.. im pretty skinny so i dont need to jack up the car to remove the sensor
I should be getting my gauge today so i'lll have some more incentive to get this thing working.
I was up late last night and realized, I never re-did the heater test [unplug th O2 from the LC1 unit]. I had it mounted under the front passenger carpet, so i had to dismantle a few things to get to it. But after doing the heater reset, and the open air calibration... IT WORKS!
I did not re-ground, or change the power source.
btw i am logging with both logworks and evoscan.. works on both.
success
BUDLoNG
success
BUDLoNG
Profoxcg
48
Feb 1, 2008 08:02 AM
