egt gauge
Old Oct 15, 2007 | 05:54 PM
AKgambler47's Avatar
egt gauge
hey guys, i have the prosport electrical boost gauge,oil pressure gauge, and egt gauge. My buddy with a IX said he will put them in, but the egt gauge will cost me more cuz of the install. is it really that hard, cuz i know you have to drill into the manifold, he said he would take it off so shavings dont get in the turbo, which is smart. Should i pay, or get a different gauge. And the reason for the hassle, i have no idea what im doing
Old Oct 15, 2007 | 06:09 PM
Celica2EVO's Avatar
I have it and love it, however, you dont need to take it off to drill it out, a good drill should pull all the shaving outward, just make sure to lube the drill bit and keep blowing the shavings out to there isnt a pile in the hole to fall into the manfold! We tapped mine and under 10 minutes and no problems at all! No need to pay extra for it!
Old Oct 20, 2007 | 08:07 PM
wrcwannabe's Avatar
Just make sure to stop before the drill breaks through, coat it with grease and all the shavings will stick to it. Runner two is where I have mine. BTW the metal is pretty thin so go easy and slow.
Milburn
Old Oct 20, 2007 | 09:36 PM
voidhawk's Avatar
If you're brave, drill it with the engine running - the positive pressure will blow shavings out.
Old Nov 11, 2007 | 04:30 AM
Prosport Gauges's Avatar
That is some really good advice....I really like the grease trick!
I learned something new today, It's going to be a good day.
BTW great choice of gauges!
Old Nov 16, 2007 | 10:55 PM
Wave's Avatar
Yeah, like Voidhawk said ... just start slowly. Once you have a start (without piercing the inside wall of the mani), start the car and let it idle. Keep drilling it out. The positive mani pressure will blow the chips out. Tap the hole with the motor running too.
Old Nov 17, 2007 | 04:48 AM
be sure to post up some pics...
Old Nov 21, 2007 | 03:57 PM
v8hater's Avatar
+1
that is what I did. Just have you friend rev the motor a little when the drill is about to make the hole into the manifold.
It took me longer to decide where to mount the guage then tap the probe lol
Old Nov 27, 2007 | 09:39 AM
dancarroll0283's Avatar
I've done that on several Evo's when installing EGT guages, and have not run into a single problem..... Saves a lot of time thats for sure!
Old Nov 27, 2007 | 09:43 AM
Lowell787's Avatar
Also make sure you don't tap the hole too deep. Tap a bit, then test how far in the probe sits. Definitely don't pay extra.
Old Nov 27, 2007 | 09:44 AM
Lowell787's Avatar
Good choice on the gauges as well. I have Prosports in my Subie. Very accurate and can't beat the price. Great bang for the buck.
Enisada
Mar 31, 2009 12:09 AM
krayzeviet
Automotosports - Illinois
Nov 27, 2006 01:37 PM
rbm3
17
May 11, 2006 10:47 AM
binsquared
Oct 26, 2004 02:33 PM
Evo23IG
Jun 2, 2004 02:55 PM
