Need Help Mounting AVIC D3 Double Din
Old Mar 13, 2008 | 10:54 PM
tabio42's Avatar
I installed an AVIC D3 Double Din Head Unit in my car with the stock radio brackets and the fitment was terrible.
I tried installing it in the upper portion and the surround would not work because the head unit was too high. Then I ghetto rigged it so I could install it in the lower portion (where there are no mounting holes) and it fits inside the surround but doesn't sit flush and doesn't come out far enough.
Anybody have any suggestions? Should I have used the upper mounting locations and drilled new holes in the brackets?
Any help is appreciated.
Thanks!
Old Mar 14, 2008 | 02:52 AM
Jameson_IXMR's Avatar
Measure and drill out the brackets. It is sort of a trial and error thing usually.
Old Mar 14, 2008 | 06:43 AM
NoTec's Avatar
I'm assuming your d3 did not come with the template in the instructions. If that is the case, just follow what Jameson IXMR said. I had to do the same thing.
Please excuse the roughness of this picture. Quick 3-min MSPaint job. Basicly, I drilled new holes where you see the green in the picture. Then I used my dremel tool and nothced the sharp overlapped areas leaving a long oval shape. It left me enough room to vertically adjust the radio as much as I liked for a perfect fit.
Old Mar 14, 2008 | 09:21 AM
tabio42's Avatar
Thanks for the replies guys. So I guess the upper mounting holes are the ones to use then right?
Old Mar 14, 2008 | 10:03 AM
felickz's Avatar
ja upper. ... .. Are you installing with the orbital kit?
Old Mar 14, 2008 | 10:18 AM
tabio42's Avatar
With the JDM/AUS double din bezel
Old Mar 14, 2008 | 03:08 PM
tabio42's Avatar
Thanks a lot for the help y'all. I got it in today. I drilled the holes lower like in NoTec's awesome tech diagram
I think it turned out that I only needed to drill the front hole because the rear is up all the way and the front is down all the way.
There was still a gap between the bezel and the headunit where you could see into the dash so I just used some stick on foam insulation to block it. It actually turned out pretty clean.
I'll post some pics later.
Old Mar 14, 2008 | 11:51 PM
Light the radio up so the gap is equal on all four sides. Then test fit the cover and make sure it looks perfectly even. Now measure the outside lengths of the face of the headunit and cut a faceplate sized hole in a piece of sheetmetal. Trim it so that it is like 1/2" border and painters tape it to the backside of the bezel. Then test-fit and move it until it fits/looks oem. Then leave the tape on and tape it to the back of the bezel with a more permanent double sided tape (I actually hot-glued it on).
Old Mar 22, 2008 | 10:59 AM
shawnhayes's Avatar
Doing this myself right now. What did you do with the HVAC, and where did you get your double din surround?
Shawn
Old Mar 22, 2008 | 11:55 AM
tabio42's Avatar
ygpm ^^
chedo
11
Mar 16, 2017 07:44 PM
bboy_RES
Feb 18, 2009 10:24 PM
kinkbmxrydr
27
Apr 8, 2008 07:39 AM
xLaNcErEvOx
Jun 20, 2007 01:20 PM
Ultimate CC
17
Jan 8, 2007 08:50 PM
