Power Loss
Old Jun 6, 2008 | 02:51 PM
Cj98's Avatar
Power Loss
Since this car is my DD im going to post before I search to see if anyone can give me an idea of whats wrong.
I have no power what so ever, nothing at all. I installed a battery relocation kit two weeks ago and everything has a good connection.
When I went to start it, I didnt let the injectors prime I just went to crank it over and it sounded like the starter was going but then just died. I went to fix it and everthing came back on and when I went to start it, once again clicked and...no power. Im not sure what to do except check my fuses
Old Jun 7, 2008 | 03:53 AM
EvoVIII808's Avatar
I think your power wire is not big enough. i had this same problem after my batt died. so i ran it to the trunk, but the first wire i got was not thick enough to cary the voltage/amps. get like 1/0 guage wire(monster cable )
Old Jun 7, 2008 | 06:05 AM
slvrr's Avatar
Where is the ground? In the trunk or did you run the wire all the way back up front? Even though you have everything good and tight doesn't mean you are getting a good ground. I would start with that.
Old Jun 7, 2008 | 11:47 AM
EvoKnievo's Avatar
check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground, check your ground.
try to keep it less than 2 feet in length.
another problem could be (as stated) not a big enough wire to cary adequate current.
Old Jun 7, 2008 | 12:32 PM
EvoVIII808's Avatar
Yup yup forgot to say ground.
Old Jun 7, 2008 | 12:47 PM
EvoKnievo's Avatar
oh yeah, dont forget to check the ground.
Old Jun 8, 2008 | 11:34 AM
Cj98's Avatar
my ground it connected right across from the box not can back up front.
Im also thinking its could be a power wire issue.
This is the kit I have:
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 10, 2008 | 02:03 AM
EvoKnievo's Avatar
make sure you have a BARE piece of metal for your ground, no painted surfaces.
EVL4B11MR
Mitsubishi TC-SST Discussion
Sep 28, 2016 08:28 PM
vinNybXx
17
Nov 8, 2011 11:05 AM
J8dailo
Aug 15, 2009 10:49 PM
Evo8Emperor
Nov 13, 2007 06:20 AM
hksevoix
Jul 28, 2007 01:52 PM
