Constant 12v Source on Radio Harness, red or yellow wire?
Old Jul 2, 2008 | 11:35 AM
Inprogress's Avatar
I'm hooking up my prosport gauges and wanted to know which wire on the radio harness was a constant 12v source, red or yellow?
Thanks!
Old Jul 2, 2008 | 11:56 AM
landis507's Avatar
yellow should be the memory wire, so there for it is the constant 12v source wire. red should be the ingition wire for the on/off for the headunit, there for the red wire is only 12v wen the car is turned on
Old Jul 6, 2008 | 07:51 AM
heel2toe's Avatar
^what he said. I dont know much about the yellow wire but if its between yellow and red the constant source would be yellow. The red wire is a switched 12v source. Why are you looking for a constant power wire. Wouldnt it make sense for your gauges to only turn on when you turn on your car or i guess accessories?
Old Jul 6, 2008 | 08:04 AM
Inprogress's Avatar
The actual wire that determines the gauge color on the prosports requires a switched 12volt, so the gauges do turn off. The constant source allows for the gauges to retain memory and what not
Old Jul 6, 2008 | 04:54 PM
heel2toe's Avatar
ok that makes sence. Sorry for my stupidity...
Old Jul 29, 2008 | 04:14 PM
J8dailo's Avatar
i just hook mine up with the wire on the clock... changes color with the color... i got prosport too by the way..
Lucas03ES
Mar 20, 2009 11:53 AM
joon82
Feb 5, 2009 05:50 PM
red evo8
Feb 1, 2006 11:26 AM
qbbraveheart
Mar 18, 2005 08:48 AM
ericomundo
Aug 18, 2003 08:06 PM
