Remote Start Issue
Old Sep 4, 2008 | 09:16 PM
SilvrEvoIX's Avatar
Remote Start Issue
Let me start off by saying the the car hasn't gave me any problems. The problem is when I want to remote start the car. The car will start but it will run for about 5 seconds then it shuts off. Maybe once a week the car wont shut off after remote start. I don't know whats going on.
Old Sep 4, 2008 | 09:27 PM
vi3txdr34m5's Avatar
immobilzer..??? or something... doesnt the installer kno??
Old Sep 4, 2008 | 09:39 PM
revvin9k's Avatar
There are programmed times you can have your car run for. What type of alarm is it to begin with?
You should go to any competent stereo shop for some easy help. Or Google.
Old Sep 5, 2008 | 08:10 AM
gsrboi80's Avatar
What is your car using to bypass the immobilizer? The Black Box? A Spare Key in the car?
Old Sep 5, 2008 | 08:18 AM
nerd's Avatar
Try leaving your parking and/or regular lights on before you shut off the car. I know it's weird, but that's how mine was programmed, maybe for safety, IDK...
Old Sep 5, 2008 | 09:43 AM
boostedteg99's Avatar
You could try to reprogram the tach signal, that would be the easiest thing to do right off the bat.....
Old Sep 5, 2008 | 12:47 PM
redboosted05's Avatar
generally the evo's will not run for any period with the immbolizer not working. I would go with checking the tach such as boostedteg99 has sad. What system are you useing? Start car hold programming switch until led lights up and stays solid then release button. Sometimes people will cut down time and program voltage check instead of running a tach signal wire.
Old Sep 5, 2008 | 01:49 PM
Dennis F's Avatar
There is some good info there.
It sounds to me like it is a DEI product setup on voltage sense instead of tach.
We need to know the brand of system you have.
Old Sep 5, 2008 | 06:24 PM
Brokenevo's Avatar
you got EMS or stock ecu?
Old Sep 6, 2008 | 09:01 PM
SilvrEvoIX's Avatar
Thanks guys for all of your suggestions. It was the little black box where the spare key goes. I checked under the dash and realized the box wasn't at the same spot. It was tossed around and the key moved out of place. I repositioned the key and box and wallah! Back to normal.
P.S. I have an Avital two-way remote alarm.
t mac
Jun 16, 2012 04:23 PM
eez4life
Oct 27, 2008 06:43 PM
fyreant
10
Aug 3, 2007 06:43 PM
jerzepnoy
Mar 24, 2005 10:24 AM
majestic lancer
Oct 27, 2003 09:36 PM
