Ciggarette/ashtray lights not working
Old Mar 2, 2009 | 01:58 AM
Positron's Avatar
I just finished up my Zeitronix wideband install. Upon putting back all the interior panels and plugging in the clip that connects to ashtray bulb & ciggarette lighter bulb, the lights did not turn on. Though there was power running in the 12v charger.
I dont think the bulbs are burnt out because they were working prior to the Zeitronix install. Or are they? How can I find out?
Old Mar 2, 2009 | 06:08 AM
timmiii's Avatar
They might have burned out. I've experienced something similar to your current situation a while back. I just replaced them with LED bulbs and they were fine, I can double check the manual to see if there a fuse controlling those lights as well.
Old Mar 2, 2009 | 06:31 AM
Mr. PSSsSt's Avatar
FCOTM Winner
^+1
Old Mar 2, 2009 | 01:46 PM
Positron's Avatar
Please let me know thanks. The situation puzzles me because all my interior lights work except for those two. If anything i will get replacemnt bulbs. I just bought the red condom covers for the bulbs.
Old Mar 2, 2009 | 06:10 PM
timmiii's Avatar
Hey man you're better off with LED's in there. Those bulbs don't last long at all not even the replacement ones i got. LED's are like $4 each and they're brighter (better color definition) and last much longer.
Old Mar 2, 2009 | 06:18 PM
Aman's Avatar
bulb is blown out . its 124 bulb single wire. very common to go out once they are used as the filament is only support by one wire. excessive shock might have been the problem.
Old Mar 18, 2009 | 08:00 PM
oodemonboioo's Avatar
i have the same problem.. ash tray, 12v socket and my hazard light button doesn't light up. if i wanted to change them to LED how would i go about doing that? anyone got a site taht sells led's?
Old Mar 19, 2009 | 09:55 AM
Positron's Avatar
I would suggest going to an alarm/car audio shop for LED bulbs. I'm about to do that this weekend.
I actually went to Autozone to replace the two burnt out bulbs. It was only $3 and I covered them in dark red transparent tape. When illuminated, it gives off this nice dark red cherry color.
Old Mar 19, 2009 | 10:10 AM
ktk's Avatar
ktk
might wanna check up on those dudes after a bit to make sure they aren't melting the tape and catching on fire...
Old Mar 20, 2009 | 01:02 AM
any one know what size for the hazard cig and ashtray bulbs?
Old Mar 26, 2009 | 10:18 PM
N33d4sp33d's Avatar
not sure but get a used one ff ebay
Old Mar 26, 2009 | 10:25 PM
Positron's Avatar
The ashtray and cig light bulbs you can buy at a local Kragens or Autozone. Just take the burnt one with you just in case to measure the correct size. Its cheap, $2-3 for a pair.
Old Apr 15, 2009 | 06:32 PM
what about the hazard light button anyone know about that?
Old Apr 21, 2009 | 04:46 PM
Maximum404's Avatar
Veteran: Navy
Did anyone find out the location of the Cig Lighter fuse?
Old Apr 21, 2009 | 09:15 PM
Wick3d3vo9's Avatar
doubt it was a fuse to begin with
