Orbital Question
Orbital Question
Hey guys, I'm getting an Alpine IVA-W505/P1 to go in the Orbital Double Din I just got.
I know this is a semi-newb question, but do I need a bracket for it or will it fit right in? Also, if I do need a bracket does anyone know where I could get one?
Thanks for the help in advance.
I did a search but it turned up nothing ( except garbage like wheel fitments for Evo Xs
I just used my factory brackets but drilled new holes in them because your double din will need to sit a bit lower compaired to holes already in brackets. Just make sure you get the angle right.
or
I know some people that have used a double din cage - if you have one available for your screen and a trim ring.
or
Aight. I haven't gotten my head unit yet but I wanted to find out so I could get any necessary parts and not have to wait when I did get it. Thanks for the help. I'll try the new holes.
I just took my install apart to fix/heat and mold the lower hvac relocation bezel that was supplied with the orbital kit. While rummaging through the garage, I found the original orbital install folder. It includes a template for drilling new holes in the dash slightly below the current holes for the radio bracket. After examining everything, I've realized that the only reasons I re-drilled the factory install brackets was to reduce how far my Kenwood unit protruded and to adjust the angle of the unit once the upper bezel was installed.
201Motorsports
Aug 12, 2008 11:10 AM
03evo4g63
13
May 10, 2008 09:12 PM
TempeRacerGuy
Sep 15, 2007 04:43 PM
johnsrt4
11
Oct 20, 2006 11:50 PM
