Lower DIN mounting with Orbital kit, help
Old Sep 14, 2007 | 04:49 AM
TempeRacerGuy's Avatar
OK, I just got my Orbital kit, and I have had my dash apart in the past, so I am working from memory here, but..
I don't seem to remember the HVAC controls mounting to a DIN type bracket. As I am using an upper DIN and lower DIN components, how am I to mount the lower DIN component properly?
Do I need to fabricate a bracket?
For what it's worth, My Top component will be an Alipine single DIN center channel speaker, and my lower is my Kenwood XXV-O5V.
Thanks
Old Sep 14, 2007 | 05:55 AM
WhiteEvo05's Avatar
The two ears (or brackets) that are mounted to the side of the stock radio...yeah, those. They supposedly will line up with the mounting holes that the climate controls mounted to.
I am looking to do similar. I am modding a Gruppe-S gauge panel to hold the radio where the climate controls were with three 60mm gauges above. When I looked in to doing it with a panel already made for this (by Colt Speed, JDM expensive stuff...) I was informed that the stock radio bnrackets held the radio in the correct position.
You may have to make your own brackets to get an aftermarket head unit to fit correctly (flush-wise).
Let us know how it goes.
Old Sep 15, 2007 | 01:02 PM
Will do. I am in AZ right now, once I get back to FL, I will be painting the orbital pieces in the factory Graphite Grey (along with the center console). Once the paint work is done, I will be working on mounting everything
Old Sep 15, 2007 | 01:11 PM
jeffbum's Avatar
sorry to get off topic, but where are you gonna get the paint to match the factory metallic look pieces??
Old Sep 15, 2007 | 02:53 PM
sgand's Avatar
GG is the color of the car, not the dash trim.
Old Sep 15, 2007 | 04:43 PM
However if I wanted to match the stock pieces, I could just take the parts to my paint store, and tell them to color match it. Scottsdale Auto Body and Paint in Scottsdale, AZ is a great pro paint store specializing in PPG paints. I picked up two rattle cans loaded with Graphite Grey, along with plastic adhesion promoter and a laquer clear.
slebo3213
15
Jun 24, 2011 09:33 AM
borievoinitialD
17
Feb 20, 2009 03:42 AM
sna08
Dec 4, 2007 03:35 PM
w8lifter21
Nov 25, 2007 01:32 PM
TheShortBus
Nov 29, 2006 04:04 PM
