Front Squirter Problems After Rear Wiper Removal
Old Nov 8, 2009 | 12:53 PM
kbc258's Avatar
I have a 2006 MR and I have just removed the rear wiper and wiper fluid reservoir. Now the front squirter's won't work but the front wipers work fine. I have capped the main front fluid line and I also tried to bleed it. I'm unsure if it is an air bubble in the line or is there something I need to do to the electrical connectors to close the circuit. I tried to do a search but I only found threads with rear wiper plug questions. If anyone one has done this and has any info it would be a great help. Thanks
Old Nov 8, 2009 | 02:04 PM
Kracka's Avatar
The front and rear share a fluid tank.
Old Nov 8, 2009 | 02:16 PM
kbc258's Avatar
I realize the front and rear feed each other but there has to be a way to eliminate rear and have the front squirters work just off the front tank.
Old Nov 8, 2009 | 05:00 PM
Resi's Avatar
You arent picking up what kracka is putting down...
basically what he just told you is there is not a front tank...the tank in the trunk provides fluid for the front squirter as well as the rear!
Old Nov 8, 2009 | 05:03 PM
ak47po's Avatar
Step away from the vehicle.
Old Nov 8, 2009 | 05:05 PM
SyZyGy1394's Avatar
Classic entertainment at its best!
Old Nov 8, 2009 | 05:34 PM
kbc258's Avatar
My mistake, you guys know all. I thought it had two wiper fluid tanks.
Old Nov 8, 2009 | 05:37 PM
ak47po's Avatar
What tank in the engine bay did you think was for the washer fluid?
Old Nov 8, 2009 | 05:42 PM
SyZyGy1394's Avatar
Hopefully not the ACD fluid container!
The only thing else would be the ICS tank, but it says IX on his prof...
Old Nov 8, 2009 | 05:56 PM
kbc258's Avatar
I actually only was working in the trunk and I thought the front squirter line went to a tank in the engine compartment.
Old Dec 1, 2009 | 06:25 PM
ymyEVOIX's Avatar
i got rearended in my EVO. It's all put back together, but now when i try to wash the wind sheild nothing comes out even though the wippers go, and when i wash the back window it squirts front and back at the same time. i took it back to the shop and they said they never touched it. i can't figure out what could be wrong.
Old Dec 1, 2009 | 06:35 PM
Evoardo IX's Avatar
Seems like they only pluged the rear pump and T'ed the hoses front and back. They should be separate, a hose to the front and a hose to the back, each coming out of its corresponding pump. Check the reservoir in the trunk, you will see what I'm talking about.
Old Dec 2, 2009 | 06:14 PM
ymyEVOIX's Avatar
Thanks, that makes since, I will check it out. The only thing is, is that the shop said they never touched it. Maybe something came off in the wreck?
