HID problem
Old May 7, 2010 | 05:25 PM
GusandoX's Avatar
HID problem
I just finished doing the DIY black housing headlight mod on my 03 evo and the driver side HID turns on then off about 2-3 seconds after i turn it on... just to make sure i checked the other headlight and everything was fine on it. i was very careful with removal and installation. Somone please help?
Old May 13, 2010 | 01:56 PM
Fourced4cyl's Avatar
Check for loose connections or dirty connections. They are voltage sensitive. One can be pulling more amps in the system and the other will shut off. Ive seen this in aftermarket HID kits. Try swapping the bulb to the other side and see if that changes anything.
Old May 13, 2010 | 02:01 PM
mifesto's Avatar
They use the ground points on the fender side of engine bay, check those. on my evo the passenger side one was flickering inconsistently but only turned out to be bad ground connection off that fender
Old May 17, 2010 | 01:57 PM
GusandoX's Avatar
cool thanks guys, the suggestions actually helped alot. the connectors we prolly a little dirty and the part of it being voltage sensitive was prolly what the problem was. thank you both
Old May 17, 2010 | 02:20 PM
Jp7's Avatar
Jp7
please update us with the solution if you find it.
Old May 19, 2010 | 07:19 PM
evoRaul's Avatar
my drivers side went out and now my passager side works here and there need help? mayble both hid bulbs are out
Old May 19, 2010 | 10:34 PM
GusandoX's Avatar
@ evo raul I had the same problem before after i did my headlight mod, turned out one of the connectors from the ballast to the HID bulb had some dirt in it and it totally melted the the plastic that connects to the bulb.
your problem might be a bad ground, bad ballast, or might even be the bulbs dieing out on you, but i kinda doubt its the bulbs.
did you do something to it recently or is it just acting up all of the sudden?
Old May 20, 2010 | 11:00 PM
evoRaul's Avatar
I replaced the a/c fan so I removed the front bumper and I install megan coilover but after putting the bumper 2 days after I notice one headlight out and then 2 days afters my passager went out I order new bulb so I well now when they get here. hey for anyone looking for ballast in sacramento 1320 performance has hid d2s ballast for stock hid 100 for both great deal lifeime warranty
Old May 20, 2010 | 11:32 PM
GusandoX's Avatar
thats cool good luck with that.
Old Jun 19, 2010 | 09:06 AM
SavEVOIX's Avatar
I have a similar problem, maybe I can get some help. When I first start my car and either my headlights auto-turn on or I turn them on, my Right side headlight turns off then flickers off. If I turn my headlights off then back on, both turn on and stay on. I only get this problem at initial start, any suggestions? I am going to be checking the grounds.
DustinDHP
Jul 10, 2015 07:26 AM
SnailSpeed
Jan 22, 2015 10:50 AM
ekinshuya
Aug 7, 2014 04:48 PM
Wapoosh
Jan 1, 2014 10:29 AM
miller121mx
Sep 4, 2010 08:16 AM
