No power to radio and clock after trying to install a aftermarket deck.
yea i just had this happe to me. Was installing gauges and then i found out i had CD's propping up the CD player and had three harness spliced to hell. Once i took out my radio nothing worked anymore. Clock, radio, dome light, no power locks, and my trip meter resets everytime i start the car. the only time my power locks work is when i have the key turned all the way. so now i need to figure out where the hell to start from.
i have this same exact problem, only i am not installing gauges at all... did yo find a pix for this?
I had the same issue, just fixed it today. However, my fuses under the hood were fine. I did some research and found I had to insert a fuse under the dash. In the manual this is labeled as the "dome light" but on the fuse block it's labeled as "B-UP." First I had to break the block-off using needle nose pliers. I popped in the fuse and the radio, clock, trip odometer and dome lights started working again.
No power to stereo lancer sports back 2010
Hi just changed my stereo. The original one was working when took it out. Now there is no power to old one or new one. I have changed all the fuses but still no luck .
hope you can help thanks
HDGamer
Jun 29, 2017 09:28 PM
Segfault
Dec 19, 2007 10:17 AM
