Please Give me Advice On Stereo
Old Jul 29, 2010 | 10:17 AM
toyotabike's Avatar
So I have a 06 Evo 9 MR and the stereo system sucks ****.....
If I was to change out the deck into something like a DVD stereo system will it make it significantly better?
I dont want to change out speakers or add amps. Not looking to spend a ton of money on this either because I am more into performance, but I just want it to sound better.
Stock CD player looks like it was made in the 80's....
Old Jul 29, 2010 | 10:21 AM
cmrs2k's Avatar
Just changing the head unit may not help your sound much if you have a factory amp that you will still be using. I am not familiar with the evo 9s but I would guess that if they have a factory amp, you will be able to find it under the driver's seat. Start by finding out if you have a factory amp or not.
Old Jul 29, 2010 | 10:31 AM
toyotabike's Avatar
I dont think the MR has a amp. If it did, it wouldnt suck so much.
This is as bad as my dad's 2000 corolla, but his car cost $12k brand new.
I would be happy if it was as good as a camry.
Old Jul 29, 2010 | 11:07 AM
adammartini's Avatar
my evo has an amazing stock sound just as good as my moms stock bose system in her car. i was very happy with it none of my other cars sounded as good and ppl that have ridden in my car think i have a sub, but i dont. but my evo is an 03' so they might have been doing things different back then.
oh u might want to check and see if all 6 speakers are working or if the amp has failed or somethig
Old Jul 29, 2010 | 12:43 PM
toyotabike's Avatar
Your system is all stock?
Old Jul 29, 2010 | 12:59 PM
Tsurugi-san's Avatar
Depends on what you think is "good" sound. I didn't get a satisfactory sound out of my Evo stereo setup until I was running an Alpine amp, sub, & speakers, upgraded Irragi alternator, yellow-top Optima, and a Kenwood Excelon DNX-9140 satnav.
If you can keep your "upgrade" under $500 bucks . . . consider yourself lucky!
Old Jul 29, 2010 | 11:27 PM
well now i have a deck but still the stock speakers but i actualy think it was better with the oem deck I only added the deck so i could put a sub in but only cuz i like hevy bass sometimes
U could just do somethin like me get a deck and sub and use ur stock speakers as mid-highs and get most of the bass from the sub but really i think my stock setup was way above ave for a lil japanese car from 03' really mine sounds great if i didnt want to bump i would have just left it 100% stock like i said it was just as good as my moms 08' with the bose speakers and ppl thought i already had a sub when it was 100% stock
so check to see if everythings workin
Old Jul 29, 2010 | 11:56 PM
Ozrally06's Avatar
i have an 06 lancer which have the same speakers and radio as the evo. when i changed my radio its sounded the same until i put in my subs. i still have the same stock speakers inside i use them as my mids and highs it gets the job done very well.
Old Jul 30, 2010 | 12:16 AM
yahu's Avatar
IMO, if you spend a considerable amount of time in the car, don't cheap-out on audio equipment. The stock tweets are ridiculously ghey, they are like paper or foam. Amp it, sub it, get some new fronts, and enjoy. Double-din nav on top of that and you will be happy!
Old Jul 30, 2010 | 12:53 AM
05VIII's Avatar
If you want some ideas then I would highly suggest alpine type r components for front and rear(around 200$) eclipse sw8212 750w rms(150$) kicker 750.1(150$) 2 gauge amp kit(50) and an alpine Ida-x305 (200) and you will be set for under 1k. That's exactly what I have and the sub pounds and hit lows really low and I put the tweets in the front doors and in the c panels in the back and it SCREAMS..everyone gives me props on my system.
Old Jul 30, 2010 | 07:06 AM
GrnEVO's Avatar
Hey man, I don't know much about the evo systems themselves, but car audio is my forte. The Evo 9 MR has an optional Rockford Fosgate sound system. If you bought it used from someone, you should try to find out if it has an RF amp/sub whatever. Easiest way to do this is to look in the trunk, lol. No sub, then you got yourself a factory crap stereo. Moving on, the easiest way to get a better system is the basics. HU (head unit) with atleast 50x4 watts, and coaxial speakers (the ones with tweeters on the speakers) an aftermarket amp and a subwoofer. This can easily be achieved for around $1000. If you want to lower the cost, you can DIY the install and I can walk you through it. I am very partial to MTX's comp series of everything, but you will get a good idea from this. Here is a good example of a low cost install that will sound great. The speakers are not MTX's top of the liine stuff, but they still sound great!
1) Sony CDX-GT340 HU, has everything you could ask for minus DVD/NAV = $95.00
2) MTX TDX6502 6.5" 2 way coaxial speakers = $100.00
3) MTX TX-6 (6.5") Component speakers w/ crossovers and 1" dome tweeters = $120.00
4) MTX 704X 4-channel amp = $150
5) MTX TS5510 - 10" Square Sub = $250.00
6) MTX 1000XD Mono Amp = $250.00
7) Kicker Installation Kit = $90
8) Distribution Block = $20.00
This would give you everything you could want in a system. Hope this gives you some insight and by the way, you have a PM.
