Sub wires?
Old Nov 15, 2010 | 01:08 PM
WolfsFang's Avatar
Sub wires?
I havent owned this car for to long so i just found these. My friend noticed a red wire just poking out of the carpet in the trunk. He says they are for subs which i believe however, there was also two other plugs that looked like AV cables. We both know nothing about a sound system so this is why im posting this. The forks are a little bent and the two AV looking cables says monster on them. Would like to know if i could reuse these wires for a sub, this would save me alot of time in the future.
Old Nov 15, 2010 | 09:37 PM
SRTRaceR04's Avatar
Looks like a power cable, ground, remote and RCA's. It's hard to tell from the pic is that 8awg wire??
Old Nov 16, 2010 | 09:27 AM
Short_Block's Avatar
Assuming the other ends are in decent condition able to be hooked up then you should be able to reuse them
The bent termination could easily be replaced if needed...
There is an item called a tone generator if you know someone who runs wire or cable you could borrow and follow their routing to help inspect and locate them.
Ben
Old Nov 16, 2010 | 10:50 AM
heel2toe's Avatar
^This
My educated guess
Red=power
Black=Ground
Blue=Remote turn on (not sure why such heavy gauge wire...)
Black monster cables are RCA's
That is everything you need to run an amp and potentially connect it to a sub.
Old Nov 16, 2010 | 11:07 AM
MechTech's Avatar
Originally Posted by heel2toe
^This
My educated guess
Red=power
Black=Ground
This.
Old Nov 16, 2010 | 12:00 PM
WolfsFang's Avatar
Thank you everyone, this saved me some time and money Going to have one of my friends take a look at it soon to see if everything is in order to reuse.
Old Nov 16, 2010 | 03:33 PM
FJF's Avatar
FJF
One other thought. Make sure the red wire is not connected to the battery, or wrap some electric tape around its bare end.
Old Nov 16, 2010 | 04:20 PM
josel_atr's Avatar
^this or else, smoke will come out. ive seen it happen.
Old Nov 16, 2010 | 09:08 PM
WolfsFang's Avatar
I dont think it has power or my car wouldent be here. I found them under the carpet, though i will still tape it up just in case.
Old Nov 16, 2010 | 09:17 PM
azinterrider's Avatar
Well check your battery to see if you have any other wires running to the positive terminal just to be sure. Usually there will be a fuse on the power wire as well.
Old Nov 17, 2010 | 08:02 AM
The guy could have left it connected and just pulled the fuse...
Ben
Old Nov 17, 2010 | 03:08 PM
WolfsFang's Avatar
I found that it is hooked up to the battery. Just dont think the fuse is in the black box thing.
Old Nov 17, 2010 | 05:02 PM
josel_atr's Avatar
did you open the black box? did you see a fuse in there? i would disconnect the positive from the battery anyway. you can easily connect it again when you get sub/amp down the road. i wouldnt leave any ends of those wires out in the open.
Old Nov 18, 2010 | 05:44 PM
Well if you haven't noticed a spark yet when you touch it to ground the fuse is probably pulled. Just get a new inline fuse and rewire it when ready
WolfsFang
For Sale - Cars For Sale
13
Mar 5, 2012 11:25 PM
SHhhhh
46
Nov 24, 2009 03:05 AM
lancer2show
Jul 18, 2009 04:09 PM
jaydm73
Mar 3, 2009 03:17 PM
jaydm73
Jan 19, 2008 03:57 PM
