HVAC light went out
Old Jan 8, 2011 | 02:47 PM
j.liu's Avatar
HVAC light went out
Hello,
I was wondering which fuse it was for the Lamp 1 of the HVAC light on the climate control.. Lamp 2 is on though only Lamp 1 is off so is it the bulb itself then? I am not sure if their both wired to one fuse... Thanks
Edit: it goes on for a bit then goes off again... What can be wrong with it!
Old Jan 8, 2011 | 04:14 PM
limp_noodle's Avatar
bulb probably blew out. Same thing happened to me. I have yet to replace it though, been too lazy
Old Jan 8, 2011 | 04:49 PM
j.liu's Avatar
lol thanks, I wonder if mitsu would replace it since its under warranty... I have to get other things replaced maybe I shall ask when I bring it in/
Old Jan 8, 2011 | 05:54 PM
one4's Avatar
check and see if one of the rear tail lights are out... open the fuse box under the hood... there will be 2 yellow lock type things holding two 7.5a fuses. the one closer to the front of the car should be the one if the right tail light is out left should be the other fuse. if the tails are working its most likely the bulb
Old Jan 23, 2011 | 06:29 PM
j.liu's Avatar
^^ THANKS It's the friggen bulb... haven't got around to getting it changed yet :/
Old Jan 30, 2011 | 08:57 AM
j.liu's Avatar
The light goes on for a bit then turns off again.. What can be the problem?
Old Jan 30, 2011 | 10:24 AM
probaby loose. check to see if its in there good.
Old Jan 30, 2011 | 03:15 PM
j.liu's Avatar
thanks i will check that!
Old Feb 7, 2011 | 05:55 PM
bambooi's Avatar
Did you ever fix this problem? What did you do?
cmross13
Jan 19, 2013 06:03 PM
oldwheelieguy
Dec 6, 2011 08:11 PM
EMSevo
Nov 15, 2011 09:03 AM
anjapower
Mar 20, 2010 12:35 PM
umiami80
Jun 16, 2003 12:31 AM
