Compustar Alarm.
Old Apr 13, 2011 | 03:36 PM
phrequenc's Avatar
Compustar Alarm.
anyone else using this alarm.
it came installed on my 9. first off, the 2way remote is freaking HUGE!
and i can't figure out how to use the remote start, but its there. Turbo timer mode works fine.
EDIT- 2nd Question: How hard would it be to upgrade to the newest model with 1mile range, and is it worth it?
what are other popular options/brands that have similar features?
Old Apr 13, 2011 | 03:45 PM
sblvro's Avatar
You need to program it to turn on the remote start. The compustar website has the user manual of all the models.
Old Apr 13, 2011 | 03:56 PM
phrequenc's Avatar
i downloaded the proper manual. it says the car needs to be in "reservation mode." but it doesn't say what to do if the turbo timer mode is enabled as well how to do it.
Old Apr 16, 2011 | 05:54 PM
phrequenc's Avatar
i got a tip from a friend who said to make sure there is a "key in the box"
Old Apr 16, 2011 | 07:10 PM
sblvro's Avatar
it doesn't need to have a key in the box anymore. if it has been programmed already the reservation mode means pulling the handbrake while the engine is still running and keep the gear in neutral. when you take out the key the engine will be still running due to the turbo timer. if the tt is on, when you close the driver door you need to press the lock button and the engine will continue to be running until it times out. if you have the tt off, as soon as you close the door the engine stops and the alarm automatically locks and arm it.
Old Apr 16, 2011 | 08:51 PM
phrequenc's Avatar
it does everything as you describe, but will not remote start when holding button II
Old Apr 16, 2011 | 09:02 PM
phrequenc's Avatar
edited first post
Old Apr 16, 2011 | 09:06 PM
sblvro's Avatar
make sure to give it time before trying the RS. the reservation mode is the only failsafe for the system and if it is not correct it will not start. btw it is press and hold II and make sure the antenna is within sight. make sure that all the connections to the antenna is right.
Old Apr 16, 2011 | 09:15 PM
phrequenc's Avatar
I will give that a try tomorrow, also, the little key on my 2way is lightened up.
doy ou konw how to turn the backlight lcd on?
Old Apr 16, 2011 | 09:56 PM
sblvro's Avatar
have you tried changing the battery of the remote? I did not see a key icon on the remote. can you take a pic?
http://www.compustar.com/ownerscorne...LCD_manual.pdf
Old Apr 17, 2011 | 07:03 AM
phrequenc's Avatar
Old Apr 17, 2011 | 09:35 AM
sblvro's Avatar
in page (37)19/22, check the remote start error diagnostic table. if you press RS and it doesn't start, the lights blink 3 times and after that it will blink the number of times depending on the fault.
1=motor running, 7=reservation mode off, etc.
Old Apr 17, 2011 | 09:40 AM
phrequenc's Avatar
I get Error Code 8 (Tach or Voltage Sensor Failing)
It has to be the tach wire, becuase if i query i can get voltage eventually..
another problem i'm having is the remote doesnt stay in sync, meaning, i can lock the doors and it will show up as locked, 15 minutes later come outside and unlock and it won't send the 2way back.
Old Apr 17, 2011 | 04:47 PM
sblvro's Avatar
maybe the previous owner did not install the RS function? just the tt.
Old Apr 17, 2011 | 05:30 PM
phrequenc's Avatar
whats wierd now is that the TT isn't working!?!?
is it possible to reinstall the newest model of this alarm if im already wired for one
