Replacing OEM HID Ballasts
Old May 22, 2018 | 04:07 PM
  #31
whoa69's Avatar
Originally Posted by llDemonll
My personal thoughts were just that the ballasts put out a constant and specific voltage to keep the bulb life at a maximum. chances are soldering won't harm that but the resistance changes or a bad solder could also mean headaches down the road for why bulbs aren't lasting as long or something
personally i'd have just sent it back and bought another with the longer cable, but if unavailable then yea solder would really be the only option
I didn't think a good solder would add much resistance but I wanted to make sure. I found some wire and ohmed it out to 0.1 ohm without any breaks. I cut, soldered, then tested it. Then repeated 2 more times for a total of 3 soldered connections. Still got .1 ohm. So if it did affect it, it would be less the .1 ohm..... .09-.01 ohm difference shouldnt have any effect that would make a noticeable difference. I was worried about the solder being a issue I'm the future so I made extra sure I did a good job with the iron. Hopefully I can find the right ballast so I don't have to do it again when the other one dies.
One negative though, my yellow DRL bulb is out now. I guess it could have been before and I never noticed. Anyone know the part number for that?
EvoLLBlue8
Jun 23, 2017 09:39 AM
VWJETTY
Mar 26, 2017 12:07 PM
SnailSpeed
Jan 27, 2017 07:47 PM
Ducky077
Evo X How Tos / Installations
Oct 13, 2016 06:12 AM
Evo47
Apr 22, 2016 08:11 AM
