Drivers side HID went out. New bulb didnt fix the issue.
Old Mar 21, 2016 | 08:41 AM
Evo47's Avatar
So my bulb went out. I replaced it since I naturally assumed the bulb was bad. Changed it with one bulb then another but still no luck. I even swapped the passenger side bulb over to the drivers side to make triple sure, but it still didn't work. The only thing that happens is that the bulb rapidly and dimly flashes 3-4 times as soon as I turn on the headlights, but after that it stays off. Could it be the hid ballast? How do I check if it's functioning properly? Any help is appreciated, can't really drive at night now.
Edit: so turned out to be the oem ballast that was the issue, the ground wasn't secured properly (looks like it's been changed already). Thanks for all the help!
Old Mar 21, 2016 | 08:54 AM
gsrboi80's Avatar
Ballast or wire gremlins
Old Mar 21, 2016 | 10:12 AM
Tekniq's Avatar
Replace the ballast.
Old Mar 22, 2016 | 07:24 AM
FlashEvolution's Avatar
Ballast, I'd test power to it first though to make sure there is not a short somewhere.
Old Mar 22, 2016 | 09:19 AM
Jonno99's Avatar
Mine did the same but I couldn't buy the bulb alone I had to buy a set of balasts and bulbs, comes in a kit, so I just replaced the balast and bulb, all this rubbish is made in china too, you can find them on eBay
Old Mar 22, 2016 | 01:50 PM
turbobird14's Avatar
HID bulbs almost never go bad, its the ballast. If this is an aftermarket kit, make sure your ground connections are clean as can be, or think about getting a capacitor kit.
Old Mar 22, 2016 | 05:58 PM
Fast_Freddie's Avatar
Veteran: Navy
You can pop the ballast out of the other side and test quickly to make absolutely sure that is the issue...
Old Apr 11, 2016 | 01:57 PM
grim~'s Avatar
This is what i did to make sure it was a ballast issue. Got one off of ebay and has been working for years.
Old Apr 11, 2016 | 03:09 PM
evodragon915's Avatar
my driver side hid just went out recently too.
how much is the labor cost to replace the whole hid kit? thanks, shop quoted me around 250. sounds a bit high just for headlights. but i guess its alright if yal say the price is good.
Old Apr 12, 2016 | 12:20 PM
grim~'s Avatar
I think i paid around $100 for my new ballast? its pretty easy to replace, just take off the front bumper, unblolt the light and the ballast is on the bottom and is held in by a few screws.
Old Apr 13, 2016 | 10:33 AM
cts4g63's Avatar
Also check for corrosion in the relay if you haven't already.
It's most likely the ballast as only one side is faulty, but I would check the whole system (bulbs to fuse) first before just going out and purchasing a ballast.
Old Apr 21, 2016 | 04:22 PM
thanks, yah a local gas station shop around my area quote me 250 as 125 hr/ rate. i thought the price was ridiculous consider just for installation.
glad i email'd evo specialist shop speedelement way cheaper and im bring it there soon!
Old Apr 22, 2016 | 08:11 AM
llDemonll's Avatar
You have to pull the bumper and the headlights plus wire anything up. 2 hours labor is a pretty good deal, but that's expensive labor
HondaFlyBy
Jul 28, 2013 10:59 AM
forbidden color
Jul 6, 2010 07:41 PM
WickedX1
Jan 10, 2010 07:20 PM
jrsimon27
22
Mar 27, 2007 09:17 AM
Soon-To-Evolve
Oct 17, 2005 06:45 PM
