Starting problem, that goes "click click". HELP!
Old Mar 4, 2012 | 02:17 AM
Jay Joel's Avatar
Hi Evom members,
I've been facing this starting problem for some time. I've searched the entire forum and i couldnt find a solution to it.
Car :
Evo 9 GT, JDM spec.
20g Buschur, cosworth 272 cams, stock ecu reflashed, relocated battery to the boot
Trouble shoot done :
replaced battery, replaced starter relay, replaced spark plugs, replaced starter, removed alarm system
Situation :
everytime i do a cold start, i will have to turn the key at least 20 to 40 times in order for the car to crank up and start. during the 20 to 40 times that i try starting it, it only produces a "click" sound. all the electronics in the car are fine, eg; cluster, guagees, turbo timer are all working.
the mechanic from the workshop that i go to, suspect its the key cylinder (or whatever you call it, where to insert the key to start the car)
anyone face this similar problem before? any one knows how to solve it? pls help!!! thank you!!!!
Old Mar 4, 2012 | 03:01 AM
evo8dreamcar's Avatar
-Double check the power wire, and ground on the starter. Make sure its not ripped or corroded.
I'm not sure on this, but i don't think the cylinder cuts off the power to crank it.
Try this
-turn key to on and make a jumper wire from battery to the starter relay. That should make it crank. If cylinder was bad i would think it would turn off randomly?
Also check the wiring going into the cylinder because maybe the turbo timer being installed someone might of done the wrong wire.
Just a few ideas to start
Old Mar 7, 2012 | 10:04 PM
Jay Joel's Avatar
thanks for the reply! tried the method above but didnt work.
here's a video reference. perhaps some one from this forum had experience this and solved it already?
http://www.youtube.com/watch?v=UKoNr...ature=youtu.be
Old Mar 11, 2012 | 02:44 PM
JDMwannabe's Avatar
My old 2g eclipse had the same problem. All I did to "band-aid" it was to wire in a hidden switch that ran power straight from the battery to the starter to force it to crank even if the key is just in the on position.
Old Mar 12, 2012 | 07:48 AM
wazzelby's Avatar
I have this same problem except it's intermittent!!! Drives me crazy. Sometimes if you put the car in neutral and roll it back a foot, it cranks right up.
Old Mar 13, 2012 | 10:45 PM
Jay Joel's Avatar
YES YES! i am experiencing the same issue as well! did you consult any mechanic? what did he say?
Old Mar 18, 2012 | 02:04 PM
JDMwannabe's Avatar
My problem was intermittent also. From my research i think that the starter is not getting enough power. Hence the click of the starter but it does not rotate. you can try to replace some of the wires for the starter with heavier gauge.
Old Mar 30, 2012 | 05:03 PM
tj@cabspeed's Avatar
i'm driving a jdm evo7 and also experienced that problem. still not buying a new starter, i saw the culprit was the worn carbon brush inside the starter's armateur. since i tried to stretch the springs that pushes the carbon to facilitate more contact to the surface, my problem's solved.
but since some of you guys already replaced the starter, i hope you tried a bnew unit.
Old Mar 30, 2012 | 05:07 PM
Sharkbite2000's Avatar
Looks like a starter problem I had that same issue check all the wires to the starter make sure everything it tight cause if it's even lose a little bit it will not work .
Old Mar 30, 2012 | 05:52 PM
hiboost2.0's Avatar
This is what I was thinking.
It sounds like power is getting to the starter solenoid, that's why it's clicking. Get a DVOM and do a voltage drop test on the cable that connects to the starter giving it power. It should read a minimum of 12v. If that's what you're getting I say your best bet is the starter motor.
Old Apr 25, 2012 | 09:04 AM
kbuss's Avatar
I had this same exact problem. Replaced my starter with a rebuilt one and now she starts everytime. I also cleaned the connections and whatnot just to be safe.
Old Oct 6, 2012 | 12:50 AM
aycynokia's Avatar
my e9 problem solved after changing the ignition switch under the steering wheels.
hatesposers
Feb 16, 2023 05:35 PM
wazzelby
Jul 18, 2015 05:46 PM
MitsuJDM
Jul 18, 2013 04:25 PM
damstr
Apr 6, 2013 06:19 PM
