gauges wont turn on
Old Jun 7, 2012 | 12:34 AM
Street240sx's Avatar
gauges wont turn on
hey there so i have an evo 8 with blue racer defi gauges. im replacing my egt gauge for a wideband,as i was wiring it in and calibrating the sensor the boost gauge and wideband stopped powering on. fuses are good and no breaks in the circuits. idk what happened. any ideas would be great thanks
Old Jun 7, 2012 | 03:26 AM
IRISHEVOX's Avatar
Street, make sure there are no breaks in the wiring and go over and retrace your work.
Old Jun 7, 2012 | 09:23 AM
seventh_rx's Avatar
Is the control unit getting/sending power? Damaged in some way?
Old Jun 7, 2012 | 09:24 AM
twabtoxer's Avatar
bad groud maybe
Old Jun 7, 2012 | 10:17 AM
sujinX's Avatar
why is this in advance?
wont turn on is either power or ground. usually power, because if its ground then u would have burned all the wires when u key'ed on. given u checked all the fuses and tapped the right power wire.
Old Jun 7, 2012 | 12:25 PM
sorry still figuring out the forum. i mainly stare at the dyno and for sale section. ive checked all the wires, redid the grounds. made sure that the sources tap for power were connected and then checked fuses
Old Jun 7, 2012 | 12:48 PM
IRISHEVOX's Avatar
any new results?
Old Jun 7, 2012 | 03:52 PM
flymx771's Avatar
Where did you tap in for power?
Old Jun 7, 2012 | 04:10 PM
i just got them to work, the person intstalled them had sketchy wiring. i made sure each is on their own fuse and power and ground. the power is from the fuse box. i belive the wiper fuse is one of them. all work now and got my innovate wideband working =) and in the pocess of it all got my o2 sensor to somehow start working again
