No power! Help!
Old Oct 26, 2013 | 09:18 PM
swalltr207jg's Avatar
No power! Help!
So I was installing my new fuel pump , and when I got it all hooked up I go to start the car and all the power goes out as I turn the key. I think a fuse is blown but can't find any blown....any ideas?
Old Oct 27, 2013 | 03:34 AM
Ausevo7's Avatar
have you checked the two fuses on the positive battery terminal?
Old Oct 27, 2013 | 08:48 AM
Yes , both fuses are fine
Old Oct 28, 2013 | 03:41 AM
Ausevo7's Avatar
Anything other than having a look myself would just be guessing, start with a volt meter and check for volts at the battery and main fuse box then the fuses inside the car. you'll find something that doesn't have power.
Old Oct 30, 2013 | 10:25 AM
DvlInDskyz's Avatar
does the power come back when you return the key to the on position (not starting it).? If so, did you rewire the pump with a relay? Maybe you connected the relay to a circuit that disbles the voltage on crank? Just somethin to check with a voltmeter.
Old Nov 5, 2013 | 10:58 AM
cordell_pearce's Avatar
I'm sure you've already checked this, but could it be that you ran your battery down and that you just have a nearly dead battery? Either that or accidentally switched terminals on the battery?
Aby@MIL.SPEC
Aug 19, 2016 09:45 AM
evotris
Jan 2, 2013 10:01 PM
Pssst
Feb 6, 2012 06:28 AM
oldwheelieguy
Dec 6, 2011 08:11 PM
