No heat after speaker install
Recently had speakers installed and now only my defroster works no matter what setting. I checked some other car forums and this may happen from disconnecting the battery. How do you recalibrate the hvac? I checked the 30 Amp fuses under the hood and the under dash fuses inside the car all look good. Am I checking the wrong fuses?
Remove the HVAC nobs behind them there are two phillips screws, take them off. You can then remove the trim around the radio. Once behind there check to make sure all the plugs are fully seated into the back of your hvac controls.
bml1024
Feb 6, 2017 11:34 AM
dgkiller
Sep 9, 2015 09:07 AM
henry22
Jul 1, 2014 09:23 PM
Darkn3s
Nov 20, 2013 07:49 AM
