Switch Blade or Flip Key Evo 8
Old Oct 20, 2014 | 09:06 AM
  #31
Evol Knievo's Avatar
Originally Posted by deeman101
You programmed the lock/unlock with the instructions in the owner's manual or you programmed the actual immobilizer with instructions in the manual? I was under the impression only dealerships can program the immobilizer transponder.
The new key is just a shell your fob guts swap directly over. I think he's referring to programing the Immobilizer. I'm also curious how you would do that.
Old Oct 20, 2014 | 10:48 PM
  #32
ZanarkO's Avatar
Originally Posted by GSpeed View Post
Here are the instructions 00EclipseMT was referring to:
Customer Key Programming (from mitsubishi-forums.com for 2004 Endeavor)
You can program new keys to the system if you have 2 valid (already registered) keys by doing the following;
1. Insert the first valid key into the ignition and turn the ignition to the "ON" position for 5 seconds.
2. Turn the ignition to the "OFF" position and remove the first key.
3. Within 7 seconds of removing the first key, insert the second valid key into the ignition and turn it to "ON" position. About 10 seconds later, the immobilizer indicator will start flashing.
4. When the immobilizer indicator starts flashing, turn the second valid key to the "OFF" position and remove it. Within 7 seconds after doing so, insert a blank immobilizer key (specially cut for your vehicle at your Mitsubishi dealer) into the ignition and turn it to the "ON" position. Perform this operation no more than 30 seconds after the immobilizer indicator starts flashing. If an error occurs, the immobilizer indicator will go off.
5. If you wish to register another key, perform the process again from step1.
NOTE
* It is not possible to register a key if:
- the immobilizer indicator goes off during the procedure
- the immobilizer indicator does not come on for 3 seconds after step 4
* The procedure will be terminated automatically if:
- more than 7 seconds elapse between removal of the first key and insertion of the second key into the ignition
- more than 30 seconds elapse after the immobilizer indicator starts flashing
Unable to confirm however, perhaps the "valet" key can be used as the second valid key if only one valid key is available, to program the blank immobilizer key!
Old Oct 20, 2014 | 10:51 PM
  #33
ZanarkO's Avatar
Well the dick that sold me my car only gave me one key so Im screwed.
Old Oct 21, 2014 | 06:17 AM
  #34
NJ9MR's Avatar
FCOTM Winner
Thumbs up
Originally Posted by Evol Knievo
They fit directly into the key. Only mod needed is cutting the immobilizer out of your old key and glue it into the new one.
Thanks for all your help!
Old Oct 27, 2014 | 06:37 PM
  #35
stefenboy's Avatar
This is what I have been searching for. I want to ask the people that did this... does the blank key come with the immobilizer chip? Is that the chip that needs to be taken out and glued into the flip key? I have both of my original keys, I do not want to cut them up and from the above post I should be able to program the new chip cause I have 2 programed keys. Correct me if I am wrong or missing anything.
Old Oct 28, 2014 | 07:12 AM
  #36
llDemonll's Avatar
No, the chip needs to be cut out of an existing key you have (and programmed if it's not for your car) and glued into the flip key housing
Old Oct 28, 2014 | 12:03 PM
  #37
osetsky's Avatar
Buy a blank transponder key.
Cut it up to remove transponder(little black wedge thing).
Glue transponder into new flip key housing. This is sort of a pain as it needs to go in the flippy housing end. Fits perfectly. Not in with fob guts though, mine didn't work there.The spring might try to get away so be careful. While you have it apart get the key itself cut. This saves you doing it twice as the key has to be out of it's housing to fit in the key cutter.
Reassemble key.
Follow programming instructions.
Mine was finnicky and needed programming 3 times, dunno why, but it's working great now.
Old Oct 30, 2014 | 09:15 AM
  #38
stefenboy's Avatar
Wasn't the first link for a blank transponder key? Wonder what was the purpose of the first link if we have to hack up the oem key as well? I want to get this done and hope someone can guide me to the correct parts. Thank You guys for all the input and for this thread.
Old Oct 30, 2014 | 01:11 PM
  #39
llDemonll's Avatar
Ah yes, you can buy one of those and program it if you want.
I meant the flip-key housing doesn't come with a transponder.
You WILL need a transponder; where you get it from is your choice
Old Oct 30, 2014 | 02:07 PM
  #40
stefenboy's Avatar
Alrite. Thank you very much! ! !
Old Jun 19, 2015 | 04:08 PM
  #41
ZanarkO's Avatar
Anyway to have a "blank" transponder programmed to a current one? I've had 5 evos and 3 transponders but each one is different meaning the car programs to the transponder not the other way around. currently I have 2 different evo 8 transponders and 1 evo 9.I need all three to work on the same car.
Old Apr 21, 2016 | 03:17 PM
  #42
labuffness's Avatar
Any pics of inside of this after mod. I received mine today and it looks like the battery location on the new one is on the opposite end of the contacts. Just wanting to see how you did it. Thanks
Old Apr 21, 2016 | 04:15 PM
  #43
labuffness's Avatar
Nevermind I got it. Now if I could just get a remote that works
Old Jul 11, 2016 | 04:59 PM
  #44
josef344's Avatar
This is amazing, I always wondered if we could do this.
I never bothered into looking it because it wasn't a big deal.
After seeing the pictures I definitely will do this.
Old Jul 26, 2016 | 02:26 PM
  #45
acid7711's Avatar
I've been wanting to do this very badly with my Evo IX key, however the links/post are very old, and most are broken. I figure if someone managed to do this to an 8, it can certainly be done to a 9 though.
