Problem With Gauges and advice
Old May 29, 2014 | 06:29 AM
nesty2's Avatar
actually i have Depo boost, Depo Oil pressure and AEM wideband gauge
my problem is that the Depo Oil pressure Sensor goes bad in 3 months over and over i changed it 3 times already... i want to buy Innovative MTX gauges.. but before i want to know if somebody here have like 1 year or more with then without sensors problem or the gauge getting crazy numbers..
Old May 29, 2014 | 10:45 AM
llDemonll's Avatar
where is your sensor hooked up? if it's a samdwich adapter, those are terrible. if it's directly in the oil filter housing, chances are vibrations are killing it
try getting a stainless line and mounting the sensor remotely so that it's not dealing with engine vibrations
Old May 29, 2014 | 01:30 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by lldemonll
where is your sensor hooked up? If it's a samdwich adapter, those are terrible. If it's directly in the oil filter housing, chances are vibrations are killing it
+1
Old May 29, 2014 | 02:40 PM
nesty2's Avatar
it's directly in the oil filter housing, can you explain me with pictures so i can solve the problem and see how to do it
Old May 29, 2014 | 02:47 PM
meckert's Avatar
with any luck you don't need pictures for this or maybe you should take it in..
remove the sender that's dead. screw in a steelbraided line, route the line somewhere "safe" in the engine bay and screw the sender back into it. Most just pull it up by the strut tower and zip tie it.
Good luck
Old May 29, 2014 | 03:59 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Here is some info that might help:
https://www.evolutionm.net/forums/ev...iscussion.html
javievo9
Jul 4, 2017 09:33 AM
Jasoob
Aug 6, 2012 07:19 PM
rcheung
Apr 24, 2012 10:29 AM
taylorgang
Jul 23, 2011 09:20 PM
Jiggerman
Apr 17, 2011 05:12 PM
