oil pressure sender unit/sensor wont fit!
Old Jul 21, 2011 | 12:02 AM
taylorgang's Avatar
So after about 3 long days I finally got all my gauges hooked up... with the exception of the oil pressure. I have DEPO gauges and an AEM wideband. Everythings working fine (boost is reading 20 psi though and I know I'm not at 20 psi because the car is on factory tune...) anyway...
Anybody know if there is a better sensor I can use?
I tried the lower and upper bolts for the sensor, and even used an angle adaptor. Nothing fits, this damn sensor is so big!
Old Jul 21, 2011 | 12:07 AM
Drifting Away's Avatar
What sensor are you talking about? And yea you could be on the factory tune however that doesn't mean the boost still isnt hitting 20psi. What are you using to control boost?
Old Jul 21, 2011 | 12:22 PM
taylorgang's Avatar
It is a DEPO oil pressure sensor
and I'm not using anything to control boost, the car still has the stock solenoid
Old Jul 22, 2011 | 10:24 AM
Skim003's Avatar
Stock boost will peak at 19-20 psi and should start to taper down as you near redline. Sounds normal to me
Old Jul 22, 2011 | 10:33 AM
binky's Avatar
Here's your solution:
http://www.amsperformance.com/cart/A...Unit-Line.html
Works great for me!
-Bink
Old Jul 23, 2011 | 07:02 AM
taylorgang's Avatar
Thanks skim! And binky, I just found the ams unit the other day! I'm gonna order it soon.
Old Jul 23, 2011 | 08:45 PM
binky's Avatar
Cool.
Make sure when you attach the line to the oil filter housing / oil pressure sensor to use thread sealer: http://www.permatex.com/products/Aut...ad_Sealant.htm
This will ensure you don't have any leaks.
-Bink
Old Jul 23, 2011 | 09:20 PM
shmooly's Avatar
Works great for me!
-Bink
this solution
_isiah
jameswwt
Aug 1, 2015 03:32 AM
05blue8
Oct 21, 2013 01:43 PM
jrank3792
Jan 31, 2012 08:48 AM
buchnerj
Feb 22, 2010 03:45 PM
maperformance
Evo 'For Sale' Electronics / Lighting / Audio
167
Aug 12, 2008 07:51 PM
