2014 touch screen radio onto 2010? HELP
Old Oct 16, 2014 | 09:45 PM
heathc84's Avatar
Hey guys I recently bought a touch screen radio from a 2014 evo to put on my 2010 evo with the RF set up. My question is, is apparently when I plug the wires from my car into the new radio it powers up but there is no sound and all my guage lights come on such as check engine lights brake lights oil lights etc. and my speedo and tach wont work. So is there an adapter to make this work or can it be fixed by splicing some of the wires? any help would be appreciated it sucks not having a radio.
Old Oct 16, 2014 | 10:27 PM
05EV08's Avatar
This should be plug and play. You should have 2 wiring harnesses that plug into the back of the radio. Mitsubishi installed all of the wiring in every car to work with either navi or non navi.
Old Oct 16, 2014 | 10:54 PM
heathc84's Avatar
Ya that's what I thought but I called mitsubishi and the service adviser said the 2014 won't hook up to a 2010 apparently it has some kind of computer module or something like that which makes it different and won't operate the same
Old Oct 19, 2014 | 08:12 AM
AWDBus's Avatar
You may get more help in the Evo 10 section.
Old Nov 17, 2015 | 10:33 AM
memogp77's Avatar
Did u get it to work?
Old Nov 17, 2015 | 11:46 AM
kilroywzhere's Avatar
Your problem is with the CANbus. Mistu changed the wiring harness in 2011. You can do it but it would take a lot of splicing and soldering. Aftermarket is the best way to go, the only thing you will loose it the stock blue tooth steering wheel controls.
Old Nov 17, 2015 | 11:58 AM
jakeleclair2000's Avatar
With the correct adaptor you can retain Steering wheel controls. A PAC SWI-RC is what you need. You will lose stock bluetooth, but most aftermarket BT systems are better anyway
Old Nov 18, 2015 | 09:25 AM
Biggiesacks's Avatar
Im sure you could repin the harness to get it kinda working, but there is a chance you will not retain full functionality. If you dont want to repin the hanrness you could buy two metra harnesses, the one that is meant to plug into the OEM connector for a 2010 and one that is meant to replace the factory connector in a 2011+. They will be color coded for the most part. Then if you want to put it back to stock its just a matter of unplugging stuff, no splicing required.
EV0lvedX
Feb 28, 2017 10:04 AM
glenn63
Oct 8, 2015 08:26 AM
Rallilancerx
Oct 19, 2014 11:38 AM
yellowevo82
Mar 8, 2013 10:48 AM
italianpryd91
57
Nov 6, 2011 12:38 AM
