Galant Hvac In EVO IX - How to Help
Old Dec 2, 2014 | 11:15 AM
phizzalot's Avatar
So I know there are several threads on this already but they all end up without the answer on how to get this done.
I took the hit in price in an effort to share the information on how to get this done for the community for free.
I know alot of people get the orbital or mod there own hvac but I'am not happy with how it looks using that technique. The galant hvac is single din and fits in an oem single din cubby nicely.
So on to the How to.
I used a multi meter to trace the galants control board and made a table for the pins left to right.
Galant 2000 Hvac tore down
Pins Wire
pin 1 Recirc led, Green Led, Defrost Led
pin 2 Empty
pin 3 Recirc Led
pin 4 Recirc Button
pin 5 Recirc Button (long) , AC (short)
pin 6 AC Button
pin 7 Green Led
pin 8 Blue Led
pin 9 Blue Led
pin 10 Defrost Led, Recirc Led, Green Led
pin 11 Defrost Button
pin 12 Defrost Button
The Evo Board is at the top in the picture and is conveintly labeld.
I am thinking on just soldering a wire from the galant contorl board over to the the connection's on the evo board for the ac/defrost/recirc/and led's but the vent control has me stuck. Any sugestions anyone?
Pic of the galant control
pic of the evo control
Looking for sugestions in figuring that part out. I will continue to work at this but am out of time today. I am thinking about using the multimeter to determine when it activates each turn. Anyways thats all for now.
Old Dec 2, 2014 | 11:55 AM
llDemonll's Avatar
I would keep the factory harness connectors and rip the connectors off the Evo HVAC board (the plug connectors on the back)
use those and create a subharness that gets soldered to the galant board, this way it's easy to revert if you need to and you're not chopping up your factory harness
Old Dec 2, 2014 | 12:12 PM
phizzalot's Avatar
Thats a good Idea llDemonll, I think that will work. I 'll give it a shot and update with pics when done.
Old Dec 8, 2014 | 04:51 PM
phizzalot's Avatar
OK here is a small Update,
I have soldered in the wiring for AC,Recirc, and Defrost
I had to add a split for the Negative side buttons on the Galant AC/Recirc Button because they are not separate like on the evo controller.
I also was able to keep the evo ac knob switch in tact and just attach one end of it to the inside of the Galant Hvac controller, pics to come on this soon...
Positive/Negative wires soldered in
Positive
569FD7A9A8F2-564-00000069FAB37802_zps5570f660.jpg" border="0" alt="
Old Feb 15, 2015 | 02:56 PM
rodent's Avatar
Any updates? Is there a way to get a quick guide on what wire goes where?
Old Dec 4, 2016 | 07:55 AM
Nads's Avatar
Any updates here?
rallykid
29
May 25, 2013 07:37 AM
evo8dreamcar
14
Jul 7, 2012 01:39 PM
shrty10135
Nov 1, 2010 10:02 PM
kyoo
Oct 12, 2008 08:26 AM
mechanix
Oct 1, 2002 11:28 AM
