2003 headlight issues
Old Mar 16, 2015 | 05:22 PM
Night12000's Avatar
Im having trouble with my passenger side headlight it the low beam went out a couple of weeks ago I bought a new bulb and ballast and installed. driver side works fine,passenger side low beam comes on for a minute then it goes off I took the passenger side headlight an plug it up on the driver side and the same thing happened it comes on but cuts off shortly after and the left side works great with the other light any opinions guys
Old Mar 17, 2015 | 08:08 AM
llDemonll's Avatar
buy a good set of ballasts instead of cheapest ones you can buy
if it does the same thing on both sides, it's 100% ballast issue
Old Mar 17, 2015 | 09:05 AM
Night12000's Avatar
I don't think it's the ballast cause the driver side works fine and I took that ballast and put in the bad to see if it would work but it didn't but that ballast works fine on the driver side
Old Mar 17, 2015 | 09:16 AM
Ev0ikon's Avatar
If the working Ballast on one side doesn't work on the other then it's your wiring that's the problem.
Old Mar 17, 2015 | 04:34 PM
llDemonll's Avatar
this is saying the passenger light doesn't work on the drivers side
if so it's an issue with the ballast / light
maknuge
AEM EMS
11
Nov 19, 2014 11:11 AM
phenem
Oct 11, 2008 08:47 PM
ThEHiTMaN
Jan 13, 2005 12:13 AM
jtc
Lancer Troubleshooting
Mar 11, 2004 08:02 AM
