Rough idle on cold start and while headlight, fog lights and high beams are on
Old Apr 20, 2017 | 08:27 AM
96ajh's Avatar
Hey guys I've been having a idleling problem with my evo 7 for over the past few weeks and just wondering if anyone has ever came across this and could help guide me on how to get it fixed
So originally I got a flat battery a few weeks ago and since then I've been having the idleling issue. Things I've done so far are replace the old battery with a new and bigger CCA, got a retune, replaced spark plugs, replaced all vacuum lines along the throttle body, checked and re-tightened all pipes, cleaned the iac sensor and maf sensor and it still is doing the same thing.
It does it on a cold start where it will kick over strong, but then the revs start to die so I have to keep the revs up for a minute or so before it can hold it itself and also when I'm driving with my headlights, foggies and high beams are on.
Im thinking it's an electrical issue since I think I've done everything else that could be done.
so like I said earlier if anyone has come across this before and knows how to fix it it would be truly appreciated!
Thanks guys!
Old Apr 20, 2017 | 09:39 AM
kaj's Avatar
kaj
Your alternator is going bad.
Old Apr 20, 2017 | 01:20 PM
96ajh's Avatar
How can it be going bad? I checked it and it was getting still between 13-15v
Old Apr 20, 2017 | 03:40 PM
kaj's Avatar
kaj
it's intermittent. Mine was "fine" too until I finally caught it messing up. At idle it was good, even under load. I used an amp meter and it also checked out okay.
On the freeway is when I noticed it really dying.
my $10 Harbor Freight tester confirmed lol
thatdudety
Sep 11, 2013 03:25 PM
Graphic
Jun 16, 2012 11:45 PM
whitedemon
Jun 4, 2011 12:29 PM
Ahnospell44
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Sep 5, 2007 01:01 PM
speedomodel
Jul 16, 2004 04:25 PM
