Tesla style screen? Has it ever been done?
Old May 5, 2018 | 06:49 PM
  #31
cleong's Avatar
Awesome, thanks - just what I needed to know. Ok then, it appears the dashboards are fundamentally different in the first place at this section. There is probably some custom fabrication required if I needed to securely mount my 7 inch screen.
Keep in mind that I am RHD/JDM, whilst the Taiwanese LHD examples such as the beige dashboard above are LHD export market versions, which is slightly more relevant to you. Nevertheless the substructure (metal brackets) seem to be the same.
Old May 13, 2018 | 01:35 PM
  #32
booosted's Avatar
Originally Posted by BluEVOIX
^ No it did not , only part i cut out was this plastic upside down “T” . My (US) Evo dash board does not look like the jdm lancers in the pics/videos posted.
Here is what I cut out. Only part missing in this pic is the hvac duct/tubing.
nice man. Waiting on my panel too.
Old May 13, 2018 | 04:32 PM
  #33
BluEVOIX's Avatar
Panel arrived. It was not in as good shape as I expected. I new couple of tabs where broken that hold the air vents, but he said “it wasnt a big deal” . But after arriving i see that it is a “big deal” because wont hold the driver side vent in place. Also he said it was black but the panel was a very dark “maroon” color with wood grain backing. So I ended up painting it black with spray can.
I lost the capability to close/block the vent because of lack of space for how I modified the hvac tubing in the back. But I can still change direction or point it up/down. Below are pics of what it looks like and to get an idea of what I did in the backend.
Old May 16, 2018 | 07:37 AM
  #34
cleong's Avatar
Looking good, you're almost there.
Old May 17, 2018 | 03:08 PM
  #35
BluEVOIX's Avatar
Installed gauges. The back peice I made from a flimsy plastic and carbon wrapped it. It's taped using double sided adhesive tape. It will do for now.
Old May 23, 2018 | 11:47 AM
  #36
booosted's Avatar
Just got my panel also.
Just got the recall on passenger airbag, once i bring my car in I plan on removing the dash and putting a 7" screen on top and gauges in the middle.
The guy said he may sell the ac vent reroute too. so i'm waiting on him for price. Too bad the usdm evo never had this nice design from the get go
Old May 23, 2018 | 06:30 PM
  #37
BluEVOIX's Avatar
^Looks good.
Are you going to use it as so, paint it or wrap it ?
Old May 24, 2018 | 11:33 PM
  #38
booosted's Avatar
Will try and paint it. And maybe add stock ac control in the bottom bezel.
Old May 25, 2018 | 06:08 PM
  #39
cleong's Avatar
Yep, you got the right bezel for the job. You could probably just plasti-dip the bezel for a better match, but it would be a pain to get the button to match while retaining the back-lit hazard triangle logo. Do check if your existing hazard light socket will match the new one that you got. I had to modify mine.
Old May 25, 2018 | 08:20 PM
  #40
booosted's Avatar
Yup i bit the bullet and just ended up buying it. The member is actually on here also. He sent me a button harness too. basically a complete set minus the ac duct
Old May 25, 2018 | 08:23 PM
  #41
booosted's Avatar
have you guys seen the soundstream unit
this might be an option for original op. cheaper than going bezel route lol
Old May 26, 2018 | 05:38 PM
  #42
cleong's Avatar
That's actually a pretty good idea, even Fast-and-Furious-cool how the second screen appears on demand, but reviews don't all seem to be enthused about it. Plus its Android-only compatibility means I don't get to play with my iOS device.
Old Jul 31, 2018 | 09:43 AM
  #43
cleong's Avatar
So I gone ahead and got my garage to do the nasty work. Instead of showing the process, I shall cut to the chase - here is the outcome.
Old Aug 1, 2018 | 12:56 PM
  #44
BluEVOIX's Avatar
^Looks really good.
What ate are you using in the top section monitor?
Old Aug 1, 2018 | 04:53 PM
  #45
cleong's Avatar
The upper screen is an aftermarket 7 inch screen intended for Taiwanese Lancers. It displays output from my HKS Camp 2 digital gauge system, in addition to OBD parameters it monitors boost, oil pressure and oil temperatures.
