Evo 9 JDM headlights not working
Old Apr 25, 2023 | 05:16 PM
UNDRCOVER_EvOix's Avatar
Hey guys so I purchased brand new JDM Evo 9 headlights (with HIDS) to replace the stock ones . I understand that the housing is different so I purchased the 9006 bulbs with the housing that fits into the JDM headlight . I also needed an adapter so I ordered that one end is the H11 - 9006 adapter . I plugged both ends in and the fog lights won’t turn on . I installed the stock fog light into the harness and it works . There must be an issue with the adapter I Purchased ? I might be missing something , if anyone else knows what it can be please let me know thank you !!
Old Apr 26, 2023 | 03:51 PM
mitsuatb's Avatar
Get a cheap multi meter that can be set for 20v DC. Attach the adapter to the stock harness. Put the black Muti meter lead to a good ground negative battery post or bright metal. Make sure no exposed connector pins can contact any metal grounds. Turn on the lights and use the red probe to check connector for 12V on one of the pins. If you don't find 12V on one of the pins the adapter is faulty or wrong. If you find 12V check the bulb.
Old Apr 27, 2023 | 08:50 AM
Thank you will do
Old May 10, 2023 | 08:59 AM
fixed was an issue with the connector. Works perfect now
James@DSR
Nov 18, 2022 05:01 PM
MattevoVIII
Apr 25, 2009 10:54 AM
jackchn152
Mar 27, 2009 07:49 AM
Duby
Jun 5, 2007 10:06 AM
cwestevo8
16
Jan 5, 2004 12:39 PM
