Evo 7 window main switch issue
Old Dec 9, 2025 | 06:44 PM
bevo7's Avatar
My main driver window switch isn’t working for any of the windows, the rear windows go down using their own switch. I checked the fuses and they’re all fine, I checked the door wire harness connector to the switch and it’s getting power. I dissembled the switch to check the board and everything seems fine, cleaned it and still nothing. The main switch is getting power and the light under the driver window switch is illuminated. I’m not sure what to do from here.
thanks
Old Dec 9, 2025 | 07:52 PM
RallySport9's Avatar
thanks
something similar happened to me same thing but i was losing power to driver door speaker, couldn't figure why since i tested it and it was getting power. turns out the harness connection from the door wiring boot only when door was closed so it would cut power then come back on when i opened it. check that wiring harness again in that boot connection, the part that looks like rubber loom. try holding the switch control and moving the boot around at the same time to see if power signal cuts in and out.
Lee123
Aug 16, 2018 04:28 PM
Wicked_Ray
Sep 24, 2015 06:23 AM
Tadt
Sep 23, 2014 08:47 AM
Gsr08
Aug 15, 2013 05:36 PM
