New turbo setup
Old Sep 25, 2004 | 11:44 AM
STFU Tuning's Avatar
Originally Posted by gnulooks
What turbo is that and what was the cost for them to custom build it for you?
Cost is in my other post. The turbo is a pieced together dual ball bearing 3052. On another EVO this turbo makes 500whp and gets 20psi by 3600rpm, holding to 8500rpm. Alot of research went into it.
Old Sep 25, 2004 | 11:46 AM
Originally Posted by EVOnoir
i love the setup. rnr is great. what turbo is that? gt30r? whos upper ic pipe is that... that thing is bad ***. is your motor built?
RnR really is great. The UIC is made by slick motorsports. The motor is very stock. I am taking it easy until my head is ready.
Old Sep 25, 2004 | 11:48 AM
Originally Posted by metaphysical
Well, just two problems: 1) Wastegate is in the wrong place. 2) You can't drive in the rain.
care to elaborate?
Originally Posted by Fourdoor
I had a similar air filter location in my Galant VR-4 and drove in the rain all the time. Do you drive in water that is bumper deep? If the answere is "no" then you can use that intake setup
It looks like the sensor on the IC pipe is a temperature sensor. I would speculate that he is running an AEM EMS and that is the intake air temp sensor for converting over to speed density instead of using a MAS.
Later,
Keith
Old Sep 25, 2004 | 11:49 AM
Originally Posted by Losharn
How long did it take you to get the turbo?
A couple of days.
Old Sep 25, 2004 | 12:30 PM
Deceit's Avatar
Setup looks good.
That manifold looks completetly different than their other 2 manifolds that they produce. Was that manifold custom built for you also?
Old Sep 25, 2004 | 01:14 PM
Originally Posted by Deceit
Setup looks good.
Thanks. Yes, it was custom built. Myself and a few others wanted something closer to equal length than their standard, but with shorter runners for road racing. I do think the standard would be good for road racing as well.
As far as their long runner equal length maniford, I still think thats the sickest looking manifold on the market, along with the AMS.
The cool part of all the RnR manifolds is the materials they use and how they are constructed. You've never seen walls that thick. Also, there are no mandrel bends to create weak spots. It's all cast bent. Very nice!
Old Sep 25, 2004 | 01:33 PM
gnulooks's Avatar
I checked all your other posts, yet I could not find the cost. Could you post a link? Who pieced the turbo together because you have my attention about what this turbo is capable of doing. I am wondering why no one else has used this turbo, is it equivalent to something like the 3037???
Old Sep 25, 2004 | 02:35 PM
The turbo itself is around $1200 or so. The manifold will cost around $850. You'll need an intake, Wastegate, lines, O2 housing....
RnR also made me a custom O2 housing that is now part of my downpipe. The Wastegate dumps back to the O2 housing.
You'll spend between 3 - 4K
I did some other stuff too like add a slim push fan so the fans are in front now. Custom lower IC pipe....
The turbo was actually concoted by a friend of mine who went through several combos before finding the ticket. Basically it's the 35R compressor cover with a 4 inch inlet and 2.5 inch outlet. 52lb wheel, .63 Exhaust side.
Old Sep 25, 2004 | 02:50 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
bump...nice setup man!
Old Sep 25, 2004 | 04:33 PM
Losharn's Avatar
Very nice all the way around. So the turbo, manifold and parts from RnR only took a couple days? That's a nice turn around. Might have to look into that.
Old Sep 25, 2004 | 05:06 PM
Give them a call. They can make it happen.
Old Sep 26, 2004 | 10:29 AM
trinydex's Avatar
is the ti piping? of do they just not have a mandrel bender?
Old Sep 26, 2004 | 10:43 AM
value's Avatar
Be careful with that low of a intake. I know a guy hit a huge puddle and sucked water into his Honda engine.
Old Sep 26, 2004 | 10:57 AM
TURBO TECH P.R.'s Avatar
hello my friends i am using a garrett GT35R TURBO on my ralliart and i am making 500+hp att the wheels if some one wants to take a look att the turbo and the complete istalation you can go to lancer ralliart show and shine forum and go to TURBO TECHP.R. LATEST PICS.you can see all details of the car including the fuel management system. enjoy.
