Slide Hammer, which one?
Old Sep 26, 2004 | 06:12 PM
bishiboy's Avatar
I'm about to change out my clutch and I'm getting all my tools together. I see you need a slide hammer to remove the shaft in the transfer case. What type slide hammer? Anybody know what size bolt goes into the shaft? There are many different slide hammer, the most common are dent puller types. I've also seen posts that you can make you own with a longer bolt, a big washer and a pipe section as the hammer. Any details would be appreciated.
Old Sep 26, 2004 | 08:15 PM
superz's Avatar
Any bodyshop dent puller style will work. The force needed is very small so dont worry about size. All pullers will let you insert a bolt or screw at the end so that wont be an issue either, good luck!
Old Sep 26, 2004 | 08:29 PM
DSMotorsport's Avatar
I actually did my trans with a sledgehammer, 3 feet of small chain, and a few metric bolts. I belive the bolts are 8mm 1.25.
bolted the chain to the axle shaft....wraped the chain around the hammer end. once swing and the shaft poped out. simple. Weight of the sledge hammer yanked it out fast.
Old Sep 26, 2004 | 08:55 PM
Zeus's Avatar
Robi uses a bolt/washer arrangement to just wrench them loose... I'm way too tired to remember the specifics right now, but it is posted in one of the threads.
kelvinTME
May 14, 2012 05:43 AM
Labrie
Mar 14, 2012 05:31 PM
silkyjohnson
Mar 12, 2011 12:15 AM
BuiltS13
Northwest Region
Jan 23, 2011 02:19 AM
funnieguy
Midwest Region
Sep 11, 2005 08:21 AM
