MR valve causing stalling
Old Sep 27, 2004 | 10:15 AM
titaniumkingpin's Avatar
i have a forge dv, MR valve, and a stock piece. stock leaks a bit, forge flutters, and the MR stalls my car.
whats going on? is this just me that can't find a right valve?
Old Sep 27, 2004 | 01:13 PM
Fireball's Avatar
Stalls it all the way out?
I have the MR Bov, and every once in a while, the rpm's will drop slightly, but I've never had it stall out completely.
Old Sep 27, 2004 | 01:21 PM
patsevo8's Avatar
Does it vent to the atmosphere? If so, do you have washers so that you can change spring tension? If so, try that.
Old Sep 27, 2004 | 01:22 PM
Eric Lyublinsky's Avatar
Not saying you did this but are you sure the got it installed the right way. I have seen many owners with it backwords.
Eric
Old Sep 27, 2004 | 01:23 PM
UFO's Avatar
UFO
I have the MR DV on my car and have no idle issues at all. Car runs great in fact.
Old Sep 27, 2004 | 01:30 PM
Guack007's Avatar
What other mods you got UFO? How is the car tuned (dynoflash, AEM,...)?
Old Sep 27, 2004 | 01:37 PM
UFO's Avatar
UFO
Perrin MBC @ 20 PSI, Buschur filter, thru-the-mail Dynoflash, and a Perrin cat-back. Pretty close to stock really.
Old Sep 27, 2004 | 01:46 PM
Stinkapuss's Avatar
Eric
What he said. Never had a problem with my MR valve.
Old Sep 27, 2004 | 02:29 PM
the car goes either real close to stalling or actually does stall. Only happens when going uphill then coming to a stop. Or when im in a parking lot going forward to reverse forward to reverse. I have turbo back exhaust, dynoflash, MBC, AEM intake.
I put my stock back in and it doesn't stall but gets close sometimes.
Old Sep 27, 2004 | 02:33 PM
could it be that my vac reading is too low? im showing 15-17 at idle.
Old Sep 27, 2004 | 02:40 PM
Guack007's Avatar
I usually show 19-21 in of vac with AC off
Old Sep 27, 2004 | 03:54 PM
i have a feeling that its something to do with my vac.
Old Sep 27, 2004 | 08:08 PM
-130 R-'s Avatar
The only time I get a stutter (MR valve in) is with the A/C on, coming to a stop. The rest of the time it's fine.
Old Sep 27, 2004 | 10:11 PM
even without AC on it happens. usually when i come to a stop quickly after climbing a uphill it happens. what does everyone read at idle for vac?
Old Sep 27, 2004 | 10:41 PM
marksae's Avatar
I have the MR valve and have the same issues whether the AC is on or off. It happens when you are taking off from a stop and step on the clutch real quick. I guess the stiffer spring of the MR valve either needs more vacuum to make it open, or the ECU needs to be slightly retuned.
