Losing boost...
Old Oct 1, 2004 | 05:10 AM
True Evo's Avatar
Losing boost...
I noticed yesterday, in a third gear pull, my car started losing boost around 5700, and dropped quickly until redline. I have the boost peak at ~20psi, and drop to ~18psi, but it dropped to about 15 before I shifted. I still have my stock CBV, and my boost controller is routed to the airline going to the CBV. Could this be the problem? Should I switch the line back to the wastegate actuator? Or is this the CBV, I never noticed this drop before.
Old Oct 1, 2004 | 10:58 AM
True Evo's Avatar
bump
Old Oct 1, 2004 | 11:03 AM
GinuwineEvo8's Avatar
You running the stock BOV? It could be leaking due to more pressure ....
The stock plastic Blowoff is known to leak =T
*shrug*
Old Oct 1, 2004 | 01:05 PM
Hatorade's Avatar
My stock bypass valve leaked right at the RPM range you're talking about. There's a post on these forums about how to pressure test them. But I bet that's the culprit.
DONNOD
Sep 28, 2016 06:32 PM
RMDZidane
Apr 21, 2013 07:26 AM
craigbb
Sep 9, 2010 07:55 PM
kekek
Jan 12, 2006 06:13 PM
zze86
Nov 24, 2005 02:17 PM
