My Dyno #'s with GT35R
I dont think those numbers are too bad. Would you mind sending me your CAL file so i can check it out and see how it compares to mine since we have the same turbo setup and same mods just different manufactures and specs on certain stuff. ALso do you have any log files you have done? What kind of pump gas are you running 91?, 92?, 93? What A/F ratios are you able to run and what kind of timing? I guess it would answer all my questions if we could swap files?
Chris
Chris
Originally Posted by Evo8tuning
Does the dynapak put a load on the car? I didnt know it had that feature.
Jason
Jason
Chris
Chris
Jason
Originally Posted by Geo@EvoStore
Whose evo is this? Where is it from? 128mph at 21 psi on a GT35R? That is sick. Definately have to see this.
__________________
__________________
Anymore timing advance and I get knock. The boost is solid at 21lbs across the board
Bigger injectors to cut down on the Duty Cycle? IDK maybe post you runs so we can see.
450whp on a 50 trim? How much boost? What are the supporting mods? I'll believe it when I see it.
Been done, quite often even with the DSM crowd. The 16G pumps 380WHP to 400WHP with an AEM and proper supporting mods. a 50 trim is way more efficient and at 21PSI moves another 250CFM's at a way colder charge, this is not too hard with proper tuning.
128 mph on pump gas and 21 psi is wishful thinking, not going to happen
Don't mistake PSI for CFM's, PSI takes a back seat to efficiency and CFM. Look at a T-25 I had the misfortune of using for a couple years on my DSM, iti would spike to 21PSI and made almost no power and would fall on its face at 18PSI do to how inefficient it was. the GT35R is a HUGE turbo, 21PSI will make BIG power and support solid pressure even past 8000RPMS, and if you have the head/cams to flow it, 128MPH is possbile, 118 on the 16G and then you effectively double thr turbo size in flow and efficency, not impossible but in the Higher end of the spectrum.
Are you currently running 128mph on pump gas? How many people on this board are currently doing that or close? Do you realize how easy it is to say that but how hard it is to do it? It is very possible, just not as easy as it sounds.
His numbers are not bad for first trip to the dyno. There is room for improvement but it is a good base.
Originally Posted by BadazzCR
No problem here running close to that
So your time on your signature is on pump gas? That is quite an acomplishment congrats. Was there any sort of additional injection used?
Originally Posted by Fas4dr
I know compressor maps aren't always 100% accurate but take a look at this and tell me if 21psi can support 500hp?
No it was on a racegas mix (26psi) larger non stock turbo
Well they did, don't know what else to tell you/
I have also seen a 11.7 @ 118 On pump gas on a STock Turbo, the turbo can push this, granted he had a big 27PSI spike and let it settle to 21PSI, the 128MPH is certainly Possible on Pump and proper tuning with proper supporting mods, he could have ALSO been lieing to me to sound kewl, IDK.
